11-08-2014, 18:06 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2214847 Status: Offline Thanks Meter: 1 | N900A Unlock Help [Solved] 1.7.3 --------------------------------------------------------- -------------------------- To connect SM-N900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. --------------------------------------------------------- -------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-N900A Mode: Normal Phone model: SM-N900A Firmware compiled date: Jan 02 2014 Firmware compiled time: 10:00:00 Firmware released date: Jan 4 2014 Firmware released time: 16:49:46 Phone IMEI: 358579-05-xxxxxx-0 SW version: M8974A-AAAANAZM-2.0.10017 --------------------------------------------------------- -------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-N900A Proper android device not found. Make shure that "USB debug" option on the device is turned on. When I use "Android/EFS manager"-"Repair Security/Wipe Security",But BOX always prompt "Proper android device not found. Make shure that "USB debug" option on the device is turned on.",But I already Turn on "USB Debugging" ,Please help me! Last edited by Octopus box; 11-10-2014 at 07:36. |
11-08-2014, 18:32 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Disconnect the phone from PC and perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Restart PC. 15. Connect the phone directly to PC. 16. Press "Read Info" in software. |
11-09-2014, 15:37 | #4 (permalink) | |
Member: 2214847 Status: Offline Thanks Meter: 1 | Quote:
Thank you for your answer !! It's the ADB driver problem but now,this phone still turned on airplne mode,cannot turning off this mode. and the Modem locked at "SM-N900A_MLG_Modem.tar",Flash other is unknown. What's wrong with this phone,OMG Last edited by WR91128; 11-09-2014 at 15:44. | |
11-09-2014, 16:04 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | To Unlock SM-N900A, do the next: 1. Install the latest Software version (Software). 2. Fully charge phone's battery. 3. Take out SIM and SD cards from the phone. 4. Make Factory data reset and wipe cache partition. 5. Root the phone. 6. Read Security and QCN backups ("Read Security", "Read QCN" buttons in the Software). 7. Make Wipe Security ("Repair Security/Wipe Security" button). 8. Write Certificate. 9. Post here the result. |
11-09-2014, 16:33 | #6 (permalink) |
Member: 2214847 Status: Offline Thanks Meter: 1 | LOG Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 --------------------------------------------------------- -------------------------- To connect SM-N900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. --------------------------------------------------------- -------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-N900A Mode: Normal Phone model: SM-N900A Firmware compiled date: Jan 02 2014 Firmware compiled time: 10:00:00 Firmware released date: Jan 4 2014 Firmware released time: 16:49:46 Phone IMEI: 359542-05-095092-0 SW version: M8974A-AAAANAZM-2.0.10017 --------------------------------------------------------- -------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-N900A Detected phone model: SM-N900A Firmware compiled date: Sat Mar 15 17:48:27 KST 2014 PDA version: N900AUCUCNC2 CSC version: N900AATTCNC2 SW version: N900AUCUCMLG Phone IMEI: 359542050950920 Phone SN: R31DA0F30WX Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Security read successfully. --------------------------------------------------------- -------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-N900A Reading info... Mode: Normal Firmware compiled date: Jan 02 2014 Firmware compiled time: 10:00:00 Firmware released date: Jan 4 2014 Firmware released time: 16:49:46 SW Version: M8974A-AAAANAZM-2.0.10017 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! QCN read successfully --------------------------------------------------------- -------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-N900A Detected phone model: SM-N900A Firmware compiled date: Sat Mar 15 17:48:27 KST 2014 PDA version: N900AUCUCNC2 CSC version: N900AATTCNC2 SW version: N900AUCUCMLG Phone IMEI: 359542050950920 Phone SN: R31DA0F30WX Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Jan 02 2014 Firmware compiled time: 10:00:00 Firmware released date: Jan 4 2014 Firmware released time: 16:49:46 SW Version: M8974A-AAAANAZM-2.0.10017 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as D:\Program Files\Octoplus \Octoplus_Samsung\BACKUP\QCN-SM-N900A-359542050950920-09- 11-2014_23-21-13-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as D:\Program Files\Octoplus \Octoplus_Samsung\BACKUP\Security-SM-N900A- 359542050950920-09-11-2014_23-24-11-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Jan 02 2014 Firmware compiled time: 10:00:00 Firmware released date: Jan 4 2014 Firmware released time: 16:49:46 SW Version: M8974A-AAAANAZM-2.0.10017 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now --------------------------------------------------------- -------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-N900A Selected file: d:\我的文档\桌面\Cert\SM-N9000Q_ 359542050950920_RF1F33CV0D.cert Detected phone model: SM-N900A Firmware compiled date: Sat Mar 15 17:48:27 KST 2014 PDA version: N900AUCUCNC2 CSC version: N900AATTCNC2 SW version: N900AUCUCMLG Phone IMEI: Unknown Phone SN: R31DA0F30WX Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now Certificate has been written successfully Please, restart the phone to apply changes |
11-09-2014, 17:31 | #8 (permalink) | |
No Life Poster Join Date: Apr 2010 Location: Pilipinas
Member: 1284799 Status: Offline Sonork: 100.1649097 Thanks Meter: 138 | Quote:
why did you overwrite the modem need to repair your modem first. then find lower octoplus version and write service imei. | |
