02-29-2016, 18:33 | #1 (permalink) |
Junior Member Join Date: Mar 2008 Location: USA
Member: 738391 Status: Offline Thanks Meter: 3 | N900T no signal problem It was refurbished by some vendor, and it seems like they've done IMEI repair. When I check phone info with Octoplus, it shows different IMEI than the one that I check from phone setting. This is first time I've seen that IMEI doesn't match from Octoplus info and actual phone info. Anyone has seen this problem? It gets blacklisted soon or later. I'm not sure if it's because there's two IMEI info. Hope somebody knows the answer |
02-29-2016, 18:44 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please check the status of IMEI Certi in *#0011# menu. Also, please post here full Software log of all operations, which You've performed with the phone. |
02-29-2016, 18:58 | #3 (permalink) |
Member: 738391 Status: Offline Thanks Meter: 3 | IMEI Certi status is PASS. when I do *#06# it shows 35751xxxxx88060 but in Octoplus info it shows Platform: Samsung Android Selected port: COM1 Selected model: SM-N900T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM53 Mode: Normal Phone model: SM-N900T Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2014 Firmware released time: 18:08:21 Phone IMEI: 357518-05-630038-7 SW version: M8974A-AAAANAZM-2.0.10025 That IMEI info from Octoplus is blacklisted, and I think that's why it doesn't grab any T-Mobile signal. |
03-01-2016, 11:08 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to perform an "Unlock" operation, then try to find and select Network manually. If problem will remain - phone's IMEI might indeed be in "black" list of Network provider. In this case try to write different Cert files from the Support Area (Cert files compatibility). |
