03-31-2015, 17:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 57
Member: 137980 Status: Offline Thanks Meter: 168 | n900t not register on network Welcome to Octoplus/Octopus Box Samsung software version 1.9.0 ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Detected phone model: SM-N900T Firmware compiled date: Wed Feb 12 21:37:28 KST 2014 PDA version: N900TUVUCNB4 CSC version: N900TTMBCNB4 SW version: N900TUVUCNB4 Phone IMEI: 359092050091226 Phone SN: RV1DA77Q0DF Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2014 Firmware released time: 18:08:21 SW Version: M8974A-AAAANAZM-2.0.10025 Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-N900T-359092050091226-31-03-2015_21-34- 18-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900T-359092050091226-31-03-2015_21-34- 19-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2014 Firmware released time: 18:08:21 SW Version: M8974A-AAAANAZM-2.0.10025 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Selected file: E:\D A T A\O C T O P U S\Samsung\FOR UNLOCK AND REPAIR\Certificates\Cert-SM-N900-358021057834883- 00000000000.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Selected file: E:\D A T A\O C T O P U S\Samsung\FOR UNLOCK AND REPAIR\Certificates\Cert-SM-N900-358021057834883- 00000000000.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Selected file: E:\D A T A\O C T O P U S\Samsung\FOR UNLOCK AND REPAIR\Certificates\Cert-SM-N900-358021058471446- RF1D93A24AK.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Selected file: E:\D A T A\O C T O P U S\Samsung\FOR UNLOCK AND REPAIR\Certificates\Cert-SM-N900_358916055426105 _R51F706Z49.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes |
03-31-2015, 17:36 | #4 (permalink) |
Member: 137980 Status: Offline Thanks Meter: 168 | same still not registerd on network Welcome to Octoplus/Octopus Box Samsung software version 1.9.0 ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Detected phone model: SM-N900T Firmware compiled date: Wed Feb 12 21:37:28 KST 2014 PDA version: N900TUVUCNB4 CSC version: N900TTMBCNB4 SW version: N900TUVUCNB4 Phone IMEI: 359092050091226 Phone SN: RV1DA77Q0DF Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2014 Firmware released time: 18:08:21 SW Version: M8974A-AAAANAZM-2.0.10025 Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-N900T-359092050091226-31-03-2015_21-34- 18-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900T-359092050091226-31-03-2015_21- 34-19-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2014 Firmware released time: 18:08:21 SW Version: M8974A-AAAANAZM-2.0.10025 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Selected file: E:\D A T A\O C T O P U S\Samsung\FOR UNLOCK AND REPAIR\Certificates\Cert-SM-N900-358021057834883- 00000000000.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Selected file: E:\D A T A\O C T O P U S\Samsung\FOR UNLOCK AND REPAIR\Certificates\Cert-SM-N900-358021057834883- 00000000000.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Selected file: E:\D A T A\O C T O P U S\Samsung\FOR UNLOCK AND REPAIR\Certificates\Cert-SM-N900-358021058471446- RF1D93A24AK.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Selected file: E:\D A T A\O C T O P U S\Samsung\FOR UNLOCK AND REPAIR\Certificates\Cert-SM-N900_358916055426105 _R51F706Z49.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Reading info... Mode: Normal Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2014 Firmware released time: 18:08:21 SW Version: M8974A-AAAANAZM-2.0.10025 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Reading info... Mode: Normal Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2014 Firmware released time: 18:08:21 SW Version: M8974A-AAAANAZM-2.0.10025 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Reading info... Mode: Normal Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2014 Firmware released time: 18:08:21 SW Version: M8974A-AAAANAZM-2.0.10025 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Reading info... Mode: Normal Firmware compiled date: Jan 29 2014 Firmware compiled time: 07:00:00 Firmware released date: Feb 12 2014 Firmware released time: 18:08:21 SW Version: M8974A-AAAANAZM-2.0.10025 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N900T Selected file: E:\D A T A\O C T O P U S\Samsung\FOR UNLOCK AND REPAIR\Certificates\Cert-SM-N900_359092051535254 _RF1D95NTDW.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes |
03-31-2015, 17:55 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Check, whether IMEI of the Cert file, which You wrote is not blacklisted in your country. If it is blacklisted - write another Cert file. If IMEI is not blacklisted - read out QCN from another, correctly working SM-N900T and write it. Also, try to write QCN which was created during "Wipe Security" operation. |
