04-19-2014, 10:55 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Unfortunately SM-N900V is currently not supported. We will add support for this device (like for SM-N900A, SM-N900T) in next update. Last edited by Octopus box; 04-19-2014 at 11:59. |
04-22-2014, 08:31 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We have prepared and sent You test Software version to PM. Please try to repair IMEI with this Software and write here the result. Note: by performing Repair IMEI operation for SM-N900V, it is possible to repair IMEI to one of the service IMEIs from the list. Currently no solution, how to repair IMEI to original value. |
05-12-2014, 01:59 | #4 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Mourocco Unlock Age: 42
Member: 2082183 Status: Offline Sonork: 100.1638535 Thanks Meter: 53 | Welcome to Octoplus/Octopus Box Samsung software version 1.5.6 ----------------------------------------------------------------------------------- To connect SM-N900V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "##366633#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: N900VVRUBMJE_N900VVZWMJE_VZW_USA (Verizon)_Android_4.3.oct Please switch your phone to the download mode and connect it to a PC. To put SM-N900V phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing SBL1 section... SBL1 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM121 Selected model: SM-N900V Mode: Emergency Unlock for SM-N900V phone in emergency mode can’t be done ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM122 Selected model: SM-N900V Mode: Normal Phone model: SM-N900V Firmware compiled date: Oct 30 2013 Firmware compiled time: 19:27:14 Firmware released date: Oct 30 2013 Firmware released time: 19:27:14 Phone IMEI: 357507-05-007580-6 SW version: SET_BY_CM Unlocking phone... Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Can't kill external ADB references. Please, close all programs that use ADB server. Firmware compiled date: Mon Nov 11 19:59:44 KST 2013 PDA version: N900VVRUBMJE CSC version: N900VVZWMJE SW version: N900VVRUBMJE Phone IMEI: B0000000 Phone SN: RV1D956TFKR Android version: 4.3 (JSS15J) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900V-B0000000-12-05-2014_01-30-57-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Please connect phone to USB cable and press OK button. Serching phone... Phone unlocking was canceled ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM122 Selected model: SM-N900V Mode: Normal Phone model: SM-N900V Firmware compiled date: Oct 30 2013 Firmware compiled time: 19:27:14 Firmware released date: Oct 30 2013 Firmware released time: 19:27:14 Phone IMEI: 357507-05-000001-0 SW version: SET_BY_CM ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM122 Selected model: SM-N900V Mode: Normal Phone model: SM-N900V Firmware compiled date: Oct 30 2013 Firmware compiled time: 19:27:14 Firmware released date: Oct 30 2013 Firmware released time: 19:27:14 Phone IMEI: 357507-05-000001-0 SW version: SET_BY_CM Unlocking phone... Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Can't kill external ADB references. Please, close all programs that use ADB server. Firmware compiled date: Mon Nov 11 19:59:44 KST 2013 PDA version: N900VVRUBMJE CSC version: N900VVZWMJE SW version: N900VVRUBMJE Phone IMEI: B0000000 Phone SN: RV1D956TFKR Android version: 4.3 (JSS15J) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900V-B0000000-12-05-2014_01-40-25-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM122 Selected model: SM-N900V Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM30 Phone connection failed Connecting to phone on COM3 Phone connection failed Selected action can’t be performed ----------------------------------------------------------------------------------- To connect SM-N900W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "##366633#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM122 Selected model: SM-N900V Mode: Normal Phone model: SM-N900V Firmware compiled date: Oct 30 2013 Firmware compiled time: 19:27:14 Firmware released date: Oct 30 2013 Firmware released time: 19:27:14 Incorrect IMEI SW version: SET_BY_CM Unlocking phone... Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Can't kill external ADB references. Please, close all programs that use ADB server. Firmware compiled date: Mon Nov 11 19:59:44 KST 2013 PDA version: N900VVRUBMJE CSC version: N900VVZWMJE SW version: N900VVRUBMJE Phone IMEI: B0000000 Phone SN: RV1D956TFKR Android version: 4.3 (JSS15J) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900V-B0000000-12-05-2014_01-46-33-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Please connect phone to USB cable and press OK button. Serching phone... |
05-12-2014, 06:59 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Do the next: 1. Write back into the phone the first Security backup ("Security-SM-N900V-B0000000-12-05-2014_01-46-33-.asec"). 2. Re-start the phone. 3. Repeat Repair IMEI operation once again. On the last stage: Quote:
12-31-2014, 02:15 | #7 (permalink) |
Insane Poster Join Date: Dec 2014
Member: 2319987 Status: Offline Thanks Meter: 10 | i Need help please on my SM-N900v verizon every time am trying to repair my IMEI and the phone read ifo but at ask me to rood the To Repair IMEI of the device, do the next steps: 1. Root the phone. 2. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 3. Write Certificate ("Write Cert" button). the phone is rooted already but when i go to wipe security or repair security at say phone was not found in the selected port: Please help |
12-31-2014, 07:31 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please disconnect all other devices from PC and reboot it. Re-enable "USB Debuging" Mode, connect the phone directly to PC motherboard USB port (don't use any USB hubs) and repeat "Read Info" operation on "Android / EFS manager" tab in the Software. Try to perform "Read Info" operation on different COM ports with enabled "Manual select" option. |
01-03-2015, 18:51 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please perform actions, mentioned in previous post and post here, or send us in PM full Software log of performed operations. |
