08-31-2014, 21:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | N900w8 Emergency Call only Repaired different imei several times .. Firmware tried both Trinidad & also canadian rogers 4.4.2 Repaired NVM manually but still emergency .. sometimes shows carrier name & some time not . maybe there is bug in octopus software ??? |
09-01-2014, 06:38 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write more another services's IMEIs from the Software list, then make Repair NVM and Repair 3G/4G. If the network is still unavailable - maybe, these service's IMEIs are in the black list of your operator. |
09-01-2014, 09:11 | #5 (permalink) | |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Quote:
Nope ... same imei works on N9005 but not working on N900W8 | |
09-01-2014, 14:23 | #7 (permalink) |
Freak Poster Join Date: May 2014 Location: Montreal
Member: 2195006 Status: Offline Thanks Meter: 19 | Exactly You have to drop the modem. Don't blame the box if you don't know what you're doing. 4.4.2 will block the IMEI certificate. It only passes if you put the modem of 4.3 |
09-03-2014, 03:56 | #10 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Toronto
Member: 2244501 Status: Offline Thanks Meter: 16 | No service after N900w8 Service IMEI repair I have the same issue.. It was successful on N900t (T-mobile note 3) but it is not working on N900w8. The service IMEI does not get connected to network even though it is a Clean IMEI in the netowrk database. I just spend 200$ to upgrade to Octopus box and it is useless. The poster above said to downgrade from 4.4.2 to 4.3. HOW CAN YOU DO THAT WITHOUT BRICKING YOUR PHONE?? I KNOW IT WILL BREAK THE WIFI AND SOME OTHER COMPONENT Last edited by Octopus box; 09-03-2014 at 06:55. |
