04-21-2014, 22:20 | #1 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1343862 Status: Offline Sonork: 1614324 Thanks Meter: 18 | n900w8 imei failed ----------------------------------------------------------------------------------- To connect SM-N900W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM364 Modelo seleccionado: SM-N900W8 Modo: Emergencia Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM363 Modelo seleccionado: SM-N900W8 Modo: Normal Modelo del teléfono: SM-N900W8 Fecha de creación del firmware: Oct 25 2013 Tiempo de compilación del firmware: 21:19:18 Fecha de salida del firmware: Oct 25 2013 Tiempo de salida del firmware: 21:19:18 Versión del SW: SET_BY_CM IMEI antiguo: 358492-05-081945-4 IMEI nuevo: 357507-05-000007-7 Realizando el backup de NVM ¡La lectura de NVM está terminada! Connecting to ADB, please waite... Fecha de creación del firmware: Thu Oct 31 15:55:47 KST 2013 PDA version: N900W8UBUBMJ4 CSC version: N900W8UWABNB1 Versión del SW: N900W8UBUBMJ3 IMEI del teléfono: 358492050819454 Phone SN: RV1D976MF3A Android version: 4.3 (JSS15J) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900W8-358492050819454-21-04-2014_15-55- 52-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Write IMEI failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM363 Modelo seleccionado: SM-N900W8 Modo: Normal Modelo del teléfono: SM-N900W8 Fecha de creación del firmware: Oct 25 2013 Tiempo de compilación del firmware: 21:19:18 Fecha de salida del firmware: Oct 25 2013 Tiempo de salida del firmware: 21:19:18 IMEI incorrecto Versión del SW: SET_BY_CM ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM363 Modelo seleccionado: SM-N900W8 Modo: Normal Modelo del teléfono: SM-N900W8 Fecha de creación del firmware: Oct 25 2013 Tiempo de compilación del firmware: 21:19:18 Fecha de salida del firmware: Oct 25 2013 Tiempo de salida del firmware: 21:19:18 Versión del SW: SET_BY_CM IMEI antiguo: 004400-15-202000-0 IMEI nuevo: 357507-05-006038-6 Realizando el backup de NVM ¡La lectura de NVM está terminada! Connecting to ADB, please waite... Fecha de creación del firmware: Thu Oct 31 15:55:47 KST 2013 PDA version: N900W8UBUBMJ4 CSC version: N900W8UWABNB1 Versión del SW: N900W8UBUBMJ3 IMEI del teléfono: Unknown Phone SN: RV1D976MF3A Android version: 4.3 (JSS15J) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900W8-Unknown-21-04-2014_18-12-09-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Write IMEI failed |
04-22-2014, 07:01 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We have sent You test Software version to PM. Try to make Repair IMEI with this Software and post here the result. |
04-22-2014, 20:14 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. We have sent You test software version. Please check Your PM, try to make Repair IMEI and post here the result. |
