05-16-2016, 08:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | N910A restarting, please how to solve? The person that brought it to me said he wanted to "Network Unlock" it and after he typed *9090# and do the unlocking, the phone started rebooting. I have downloaded android version 5.1.1 and flashed it, but is still restarting, please how will I solve the problem? Below is flashing log; Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- To connect GT-N7000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N910A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Selected firmware file: AP_N910AUCU2DOI2_CL5613584_QB6196496 _REV00_user_low_ship_MULTI_CERT.oct Please put the phone into Download Mode and connect USB cable. To put SM-N910A into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing PERSIST section... PERSIST section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.2.5 software version |
05-16-2016, 11:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Processing of SM-N910A phone doesn't require changes in *#9090# menu. You can try to use solutions suggested in this thread: http://forum.gsmhosting.com/vbb/f684...-step-1961415/ |
05-16-2016, 14:32 | #3 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
can it be possible to downgrade 5.1.1 to 4.4.4, I thought the bootloader is locked? | |
05-28-2016, 04:10 | #5 (permalink) |
Member: 576282 Status: Offline Thanks Meter: 145 | Sir I have tried it and as suspected, it can't flash because of that the version 5.1.1 that the guy used to flash it before has locked booloader, please is there any other solution or any way to downgrade the 5.1.1 to 4.4.4? Thanks in advance! |
