07-06-2015, 20:53 | #1 (permalink) |
No Life Poster Join Date: Apr 2015
Member: 2385655 Status: Offline Thanks Meter: 99 | n910c emergency calls only after update 5.0.1 solution Selected port: COM350 Selected model: SM-N910C Searching for a phone. Please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Wed May 6 15:17:37 KST 2015 PDA version: N910CXXU1BOE1 CSC version: N910COJV1BOE1 SW version: N910CXXU1BOE1 Phone IMEI: Unknown Phone SN: RF8FC16MTMJ Android version: 5.0.1 (LRX22C) Last edited by Octopus box; 07-07-2015 at 17:31. |
07-06-2015, 20:55 | #2 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | write cert files but not avilble urlt cable how to salve this problem imei ok but emergency calls only with UART avilble but not warking how to salove this problem writh cert files uart cable? Last edited by Octopus box; 07-07-2015 at 09:35. |
07-07-2015, 09:35 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What problem with "Write Cert" operation You have exactly? Please post here full Software log of "Write Cert" operation. Last edited by Octopus box; 07-07-2015 at 17:31. |
07-07-2015, 14:18 | #4 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | n910c emergency calls only after update 5.0.1 solution Platform: Samsung Android Selected port: COM18 Selected model: SM-N910C Selected file: C:\Users\sadiq\Downloads\Cert-sm-n910c_ 355025060390000.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N910C Firmware compiled date: Wed May 6 15:17:37 KST 2015 PDA version: N910CXXU1BOE1 CSC version: N910COJV1BOE1 SW version: N910CXXU1BOE1 Phone IMEI: Unknown Phone SN: RF8FC16MTMJ Android version: 5.0.1 (LRX22C) Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed |
07-07-2015, 14:22 | #5 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | n910c emergency calls only after update 5.0.1 solution UART cable to the Box not warking i open cable to resistor ok i chang to resiston?my problem salove? how to new resistor chang?n910c emergency calls only how to salove this priblem need uart cble infarmation all time not warking |
07-07-2015, 14:38 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | In order to connect the phone via UART, You need to block highlighted pin with a tape/paper and use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. |
07-08-2015, 13:05 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write different Cert files. Make Factory Reset and try to reflash the phone again with different firmwares. |
