03-20-2016, 14:41 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | N910F after flash ...not go to manu I have the set Sm-N910F Condition before flash--- baseband known firmware version 5.0.1 So I decided to flash the set Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- To connect SM-N910F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ISelected firmware file: N910FXXU1COJ5_N910FOJK1COK1_ILO_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-N910F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.2.1 software version after flash it restart in this stage upload gambar please advice me to recover this set Thanks. |
03-21-2016, 13:31 | #4 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | facroy reset....same bro repair efs Platform: Samsung Android Selected port: COM1 Selected model: SM-N910F To put SM-N910F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Repairing EFS... EFS Repair successfully Performed by 2.2.2 software version also same bro... How to fix this...? Thanks. |
04-27-2016, 08:56 | #6 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Bro...problem is dm-verity verification failed in the recovery mode.How to fix this bro. because of this error phone is restart loop Thanks. |
04-27-2016, 11:34 | #8 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
I tried. but not completely power on I used this steps to root http://forum.gsmhosting.com/vbb/f684...-mode-2027850/ i want to on the phone to previous condition.Colud you pls help me bro Thanks. | |
04-28-2016, 06:45 | #10 (permalink) | |
after factory reset only the first Galaxy note 4 logo menu and restart upload images free Thanks | |
04-28-2016, 13:41 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please try to reflash the phone with "N910FXXS1CPC6_N910FAUT1COJ1_AUT_Android_5.1.1 " firmware from the Support Area, then check whether phone powers on correctly. |
04-30-2016, 12:34 | #13 (permalink) | |
2.2.5 ----------------------------------------------------------------------------------- To connect SM-N910F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Selected firmware file: N910FXXS1CPC6_N910FAUT1COJ1 _AUT_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-N910F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.2.5 software version Please put the phone into Download Mode and connect USB cable. To put SM-N910F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.2.5 software version but this time like this (lattes in English language) image host and restart still " dm-verity verification failed" How to fix this problem bro Thanks. | |
