02-06-2016, 11:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. Please post here full Software logs of all operations, which You've performed, or tried to perform with the phone. Also, please read phone's info from "Android/EFS manager" tab of the Software and post here full Software log of "Read Info" operation. |
02-06-2016, 13:24 | #3 (permalink) |
Freak Poster Join Date: Jul 2008 Location: morocco Age: 44
Member: 821750 Status: Offline Sonork: 19790515 Thanks Meter: 29 | Welcome to Octoplus/Octopus Box Samsung software version 2.1.9 ----------------------------------------------------------------------------------- To connect SM-N910F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM118 Selected model: SM-N910F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM118 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM118 Selected model: SM-N910F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM118 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM118 Selected model: SM-N910F Selected file: C:\Users\badaoui ayya\Desktop\cert\Cert-sm-n910f_ 354594060264664.cert ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N910F Firmware compiled date: Thu Nov 20 17:13:13 KST 2014 PDA version: N910FXXU1ANK5 CSC version: Unknown SW version: Unknown Phone SN: 00000000000 Android version: 4.4.4 (KTU84P) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM118 Selected model: SM-N910F Reading info... Phone was not found on the selected port! Operation was failed! **9090* no thing RESET MSL ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM118 Selected model: SM-N910F Reading info... Phone was not found on the selected port! Operation was failed! |
The Following User Says Thank You to abdelouahabido For This Useful Post: |
02-06-2016, 13:27 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Write Cert" operations. It is not possible to repair IMEI, if phone's modem part is damaged. If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). | |
02-08-2016, 10:25 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | If after writing of all firmwares, which You have problem remains the same - yes, You can try to repair EMMC with tool which supports this model. |
