04-17-2016, 02:56 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Tanzania
Member: 14229 Status: Offline Thanks Meter: 135 | N910H The phone displays available networks but doesn’t register on it [Solved] I know I am not the first one to post about this issue. I have searched for solution but couldn't find any successful post. I have Samsung Note4 n910H running on 5.1.1 rooted. The phone displays available networks but doesn’t register on it. Manually selecting networks says unable to connect try later. The phone came to me with bootloop. I understand that someone tried to write different csc and couldnt pass hidden.img. I had to flash the same region firmware (N910HXXU2COJ4_N910HOJV2COJ1_AFR.zip) but every time stop on hidden.img. Tried more than 5 files ( CSC = AFR ) So To solve it I had to flash CF-Auto-Root-tre3g-tre3gxx-smn910h.zip. Now phone does not register on network, I’ve tried to write different compatible Cert files (Cert-sm-n910c-355025068585692, Cert-sm-n910c_355025068700887, Cert-sm-n910c_355025068700770, Cert-sm-n910c_355025060390000 ) but still same problem. LOG Platform: Samsung Android Selected port: COM12 Selected model: SM-N910H Selected file: C:\Users\pl\Downloads\Cert-sm-n910c_ 355025068700770.cert ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N910H Firmware compiled date: Wed Oct 28 20:49:42 KST 2015 PDA version: N910HXXU2COJ4 CSC version: N910HOJV2COJ1 SW version: N910HXXU1COJ2 Phone SN: RF1FA2B3BNX Android version: 5.1.1 (LMY47X) Country: Kenya HW platform: exynos5 HW Chip: exynos5433 HW Modem: DB7450R Codename: tre3gxx Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM3 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.2.4 software version Last edited by Octopus box; 04-22-2016 at 10:01. |
04-17-2016, 21:53 | #3 (permalink) |
Member: 14229 Status: Offline Thanks Meter: 135 | The "Repair Network" button is greyed-out and does not work and Network Repair will not work either. Can you please help how to repair network ? Can anyone suggest anything I can still check/fix? its N910H and not N910C please mods correct the head title. |
04-18-2016, 10:48 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to different Cert files one by one. IMEI of Cert files, which You've used might be provider's "black" list. |
