02-02-2016, 21:06 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: Haiti
Member: 1940476 Status: Offline Thanks Meter: 27 | N910T Write Cert problem |
02-03-2016, 10:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Problem which You've discribed is most likely caused by new Security Type. This problem with SM-N910T is under research at the moment. Please upload first Security backup of the phone, which You have to any file-sharing service. Also, please upload *.log and *.logx files of performed operations. Post here download links for these files - we will add them to research. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. Last edited by Octopus box; 02-04-2016 at 14:08. |
02-03-2016, 23:29 | #3 (permalink) |
Member: 1940476 Status: Offline Thanks Meter: 27 | The weird thing was, the one I did successfully wrote cert has the same firmware and everything. But here are the logs. 02-02-2016_15-01-27 02-02-2016_15-01-27 |
02-04-2016, 13:29 | #4 (permalink) |
Member: 1940476 Status: Offline Thanks Meter: 27 | It appears that this new SW version cant be unlocked by octoplus at all. I tried to perform an unlock operation to give you security backup file and its not backing up at all. Welcome to Octoplus/Octopus Box Samsung software version 2.1.9 ----------------------------------------------------------------------------------- To connect SM-N910T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM69 Selected model: SM-N910T Mode: Normal Phone model: SM-N910T Firmware compiled date: Sep 25 2015 Firmware compiled time: 11:00:00 Firmware released date: Nov 9 2015 Firmware released time: 15:39:49 Phone IMEI: 354594-06-393870-2 SW version: MPSS.DI.3.0.c5-00436-M9625TAARANSZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM69 Selected model: SM-N910T Reading info... Mode: Normal Firmware compiled date: Sep 25 2015 Firmware compiled time: 11:00:00 Firmware released date: Nov 9 2015 Firmware released time: 15:39:49 SW Version: MPSS.DI.3.0.c5-00436-M9625TAARANSZM-1 ADB server killed. Detected phone model: SM-N910T Firmware compiled date: Mon Nov 9 22:04:39 KST 2015 PDA version: N910TUVU2DOK2 CSC version: N910TTMB2DOK2 SW version: N910TUVU2DOK2 Phone SN: RF8G115KDTL Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-N910T-04-02-2016_07-24-41 file Unlocking phone... Phone unlocking failed |
02-04-2016, 14:09 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As we already posted previously, this problem is most likely caused by new Security Type. We are researching the problem at the moment and will inform You about possible solution. |
02-04-2016, 14:53 | #6 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: NYC
Member: 1105429 Status: Offline Thanks Meter: 118 | Quote:
Had the same phone yesterday... All failed... BUT another tool worked perfect.. If you have try it Sent from my iPhone using Tapatalk Last edited by Octopus box; 02-04-2016 at 15:02. | |
