05-08-2016, 17:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: usa
Member: 2372074 Status: Offline Sonork: 100.1663814 Thanks Meter: 167 | n910u frp remove not supported ----------------------------------------------------------------------------------- To connect SM-N910U phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910U To put SM-N910U into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..not supported Resetting EE lock..not supported Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.4 software version |
05-09-2016, 10:44 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to reflash the phone with older (by release date) firmware, then repeat "Reset FRP/Reactivation/EE" operation. Also, please use the latest Software version. |
05-09-2016, 12:00 | #3 (permalink) |
Member: 2372074 Status: Offline Sonork: 100.1663814 Thanks Meter: 167 | Platform: Samsung Android Selected port: COM1 Selected model: SM-N910U To put SM-N910U into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..not supported Resetting EE lock..not supported Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.5 software version |
05-09-2016, 15:43 | #4 (permalink) |
No Life Poster Join Date: Nov 2010 Location: THE MOBILE SHOP
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | HI, IF YOU HAVE PROBLEM IN RESET FRP TRY THIS -------- Samsung New Security Frp Lock Solution Sidesync Click Here To Download SideSync | Samsung For Windows:http://downloadcenter.samsung.com/co...c_4.3.0.92.exe For Mac:http://downloadcenter.samsung.com/co....0.15125_9.dmg Steps: 1. Download and install SideSync on your pc 2. Open SideSync and connet your Mobile 3. A menu will appear to choose Browser choose Internet Browser 4. Go to alnajat.co/setting.apk -----or------- http://www.kaavu.com/lock.apk 5. Click on Bookmarks -> History -> Download history 6. Install setting.apk 5. Open Settings.apk and then go to security and make a pin for screen lock 0000 6. Go to Other security settings - > trusted agents -> turn off google smart lock 7. Go to easy mode and choose Easy mode then done 8. Go back to setting.apk and choose standard mode and then done 9. Keep repeating step 7-8 until the home screen appears in normal mode 10. Go to google play, and enter your pin 0000 and set up and new google account 11. Restart the phone once completed, then go to Settings - > accounts and remove the google account 12. Go to download mode and VOILA! .... FRP Lock: OFF Now to a Factory reset and go through the activation process normally it will not ask for Gmail to activation |
The Following User Says Thank You to sunilkumar70791 For This Useful Post: |
