05-11-2016, 10:34 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. There is no separate firmwares for dual SIM edition of SM-N920C. You can use firmwares of SM-N920C from the Support Area. |
05-11-2016, 12:10 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Currently IMIE of SM-N920CD can be repaired only via "Write Cert" operation. Cert files, which we have at the moment, are available in "Samsung/For unlock and repair/Certificates" folder of the Support Area (Cert files compatibility). To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. Also You can use Files Downloader on "Support & options" tab of the Software to browse, search and download files from the Support Area. |
05-11-2016, 13:58 | #5 (permalink) | |
Insane Poster Join Date: Dec 2006 Location: Hungary
Member: 414226 Status: Offline Thanks Meter: 4 | Quote:
05-11-2016, 14:05 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please check Certificate files compatibility list: https://docs.google.com/spreadsheets...TSE/edit#gid=0 Certificate files of phones with same "Key ID" are compatible. |
05-11-2016, 15:05 | #7 (permalink) | |
Executing exploit failed Writing certificate failed N920CD has 5.1.1 firmware | |
05-12-2016, 11:04 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please remove SIM card from the phone, then try to write a Cert file again. If problem will remain - reflash the phone, root it with CF Auto Root, then repeat "Write Cert" operation. Post here result and full Software logs of your actions. |
05-12-2016, 16:03 | #10 (permalink) | |
I trying to flash again the unit, flash successfully finished but unit hangs on Samsung Galaxy Note 5 logo. Do you have idea? | |
05-12-2016, 16:10 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please root the phone, then check whether phone boots completely. |
05-13-2016, 09:16 | #12 (permalink) |
Member: 414226 Status: Offline Thanks Meter: 4 | Root help, phone switch on. I can not post software log beacuse I flash the phone via Odin, and I can not get details from it. Rest below: Welcome to Octoplus/Octopus Box Samsung software version 2.2.2 ----------------------------------------------------------------------------------- To connect SM-N920C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-N920CD Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Performed by 2.2.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-N920CD Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Warning: Selected model (SM-N920CD) differs from the detected one (SM-N920C)! If you want select (SM-N920C) as (SM-N920CD) model, please check "manual select". Performed by 2.2.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-N920CD Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N920C Firmware compiled date: Tue Jan 19 11:44:23 KST 2016 PDA version: N920CXXU2APA2 CSC version: N920COJV2APA1 SW version: Unknown Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Performed by 2.2.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-N920CD Selected file: C:\Documents and Settings\Rendszergazdi\Desktop\n920c \cert-sm-n920t_353756070698188_rf8g72l7d1r.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N920C Firmware compiled date: Tue Jan 19 11:44:23 KST 2016 PDA version: N920CXXU2APA2 CSC version: N920COJV2APA1 SW version: Unknown Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N920CD-Unknown13-05-2016_09-55-38-.asec file Select Certificate2... Selected file: C:\Documents and Settings\Rendszergazdi\Desktop\n920c \cert-sm-n920t_354035070103799_rf8g82h36wm.cert Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Executing exploit failed Writing Certificate failed Performed by 2.2.2 software version |
05-13-2016, 12:27 | #13 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). It is not possible to repair IMEI, if phone's modem part is damaged. Also, please use the latest Software version. | |
