03-17-2016, 14:41 | #1 (permalink) |
No Life Poster Join Date: May 2006 Age: 44
Member: 278546 Status: Offline Thanks Meter: 145 | N920g AFTER WRITE SBOOT FRP LOCK REMOVED SUCCESS FULL Welcome to Octoplus/Octopus Box Samsung software version 2.2.2 ----------------------------------------------------------------------------------- To connect SM-N920G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: SBOOT_N920G_OJ4.oct Please put the phone into Download Mode and connect USB cable. To put SM-N920G into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.2.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-N920G To put SM-N920G into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Reset operation completed! Performed by 2.2.2 software version THANKS TO OCTOPUS Last edited by Octopus box; 03-17-2016 at 14:54. |
The Following User Says Thank You to yalamandareddy For This Useful Post: |
