05-25-2017, 17:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Canada Toronto
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | N920T frp Problem [Solved] Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing Firmware Failed Performed by 2.5.4 Software version. Phone stuck on samsung logo or not flash with file stuck on frp blocked any have sulotion phone not on normal mode....Not root any file. Last edited by Octopus box; 05-27-2017 at 07:24. |
05-26-2017, 07:18 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Are there any errors on phone screen during "Write Firmware" operation? What firmware are You trying to write exactly? |
05-26-2017, 08:54 | #5 (permalink) | |
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | N920t Quote:
No error during flash ....99% finals at stage show error blocked by frp...use 6.0.1 N920TUVS4DQA2...after read pit phone on show recovery mode and dm verity verification failed...frp blocked phone not root any file. | |
05-26-2017, 09:24 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If phone has FRP lock and corrupted DRK - You need to write combination firmware and make DRK fix via UART. After this try to reset FRP by known methods. |
05-26-2017, 13:58 | #7 (permalink) |
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.2 ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. Selected firmware file: combination_fa51_n920tuvu3aph1_cl6509480 _qb10649153_2.oct Please put the phone into Download Mode and connect USB cable. To put SM-N920T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing Firmware Failed Performed by 2.5.2 Software version. file not wirte :check fail device 4 binary 3 |
05-26-2017, 14:23 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | This error means that Combination firmware is not compatible with current firmware of the phone. You should try to write different Combination firmware. http://forum.gsmhosting.com/vbb/f684...rrors-2189001/ |
