07-20-2017, 04:51 | #3 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Indonesia
Member: 2155369 Status: Offline Thanks Meter: 706 | Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\20-07-2017_08-59-54.log" created (20/07/2017 08:59:58). INFO : 20/07/2017 09:00:27 > Set up system language English (file: English.ini) INFO : 20/07/2017 09:00:27 > Welcome to Octoplus/Octopus Box Samsung software version 2.5.6 INFO : 20/07/2017 09:00:44 > ----------------------------------------------------------------------------------- INFO : 20/07/2017 09:00:44 > To connect SM-J105F phone you have to perform the following steps: INFO : 20/07/2017 09:00:44 > 1. Disconnect USB cable from phone. INFO : 20/07/2017 09:00:44 > 2. Go to Menu->Settings->More->About Device. INFO : 20/07/2017 09:00:44 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 20/07/2017 09:00:44 > 4. Go to Menu->Settings->More->Developer options. INFO : 20/07/2017 09:00:44 > 5. Turn on "USB Debugging" option. INFO : 20/07/2017 09:01:03 > ----------------------------------------------------------------------------------- INFO : 20/07/2017 09:01:03 > To connect GT-I9100 phone you have to perform the following steps: INFO : 20/07/2017 09:01:03 > 1. Disconnect USB cable from phone. INFO : 20/07/2017 09:01:03 > 2. Go to Menu->Settings->Applications->Development. INFO : 20/07/2017 09:01:03 > 3. Turn on "USB Debugging" option. INFO : 20/07/2017 09:01:03 > 4. When message is appear press "Yes". INFO : 20/07/2017 09:01:03 > 5. Go to dial window. INFO : 20/07/2017 09:01:03 > 6. Enter "*#7284#" number. INFO : 20/07/2017 09:01:03 > 7. Set "USB" radio button to "PDA" value. INFO : 20/07/2017 09:01:03 > 8. Press Home button. INFO : 20/07/2017 09:01:03 > 9. Go to dial window. INFO : 20/07/2017 09:01:03 > 10. Enter "*#9090# or *#0808#" number. INFO : 20/07/2017 09:01:03 > 11. Set "Diag config" to "USB" value. INFO : 20/07/2017 09:01:03 > 12. Restart phone. INFO : 20/07/2017 09:01:03 > 13. Press "Read Info" in software. INFO : 20/07/2017 09:01:18 > Selected firmware file: I9100DXLSD_I9100OLBLSD_I9100DXLS8_HOME.oct WARN : 20/07/2017 09:01:21 > Please put the phone into Download Mode and connect USB cable. WARN : 20/07/2017 09:01:21 > To put GT-I9100 into Download Mode, You have to perform the following steps: WARN : 20/07/2017 09:01:21 > 1. Reconnect the battery. WARN : 20/07/2017 09:01:21 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 20/07/2017 09:01:21 > 3. When phone turns on, press "Volume+" key. INFO : 20/07/2017 09:01:21 > Found phone on INFO : 20/07/2017 09:01:21 > Firmware write started. INFO : 20/07/2017 09:01:21 > Writing BOOT section... INFO : 20/07/2017 09:01:23 > BOOT section has been written successfully. INFO : 20/07/2017 09:01:23 > Writing FACTORYFS section... INFO : 20/07/2017 09:03:29 > FACTORYFS section has been written successfully. INFO : 20/07/2017 09:03:29 > Writing PARAM section... INFO : 20/07/2017 09:03:33 > PARAM section has been written successfully. INFO : 20/07/2017 09:03:33 > Writing SBL1 section... INFO : 20/07/2017 09:03:35 > SBL1 section has been written successfully. INFO : 20/07/2017 09:03:36 > Writing KERNEL section... INFO : 20/07/2017 09:03:39 > KERNEL section has been written successfully. INFO : 20/07/2017 09:03:39 > Writing MODEM section... INFO : 20/07/2017 09:03:44 > MODEM section has been written successfully. INFO : 20/07/2017 09:03:44 > Writing CACHE section... INFO : 20/07/2017 09:03:55 > CACHE section has been written successfully. INFO : 20/07/2017 09:03:55 > Writing HIDDEN section... INFO : 20/07/2017 09:05:37 > HIDDEN section has been written successfully. INFO : 20/07/2017 09:05:39 > Firmware writing successfully completed. INFO : 20/07/2017 09:05:39 > Performed by 2.5.6 Software version. INFO : 20/07/2017 09:28:15 > ----------------------------------------------------------------------------------- INFO : 20/07/2017 09:28:15 > To connect GT-S5360 phone you have to perform the following steps: INFO : 20/07/2017 09:28:15 > 1. Disconnect USB cable from phone. INFO : 20/07/2017 09:28:15 > 2. Go to Menu->Settings->Applications->Development. INFO : 20/07/2017 09:28:15 > 3. Turn on "USB Debugging" option. INFO : 20/07/2017 09:28:15 > 4. When the message appears press "Yes". INFO : 20/07/2017 09:28:15 > 5. Connect USB cable to the phone. INFO : 20/07/2017 09:28:15 > 6. Press "Read Info" in software. INFO : 20/07/2017 09:28:32 > Selected firmware file: PDA_S5360DXKJ3_REV05.oct WARN : 20/07/2017 09:28:35 > Please put the phone into Download Mode and connect USB cable. WARN : 20/07/2017 09:28:35 > To put GT-S5360 into Download Mode, You have to perform the following steps: WARN : 20/07/2017 09:28:35 > 1. Reconnect the battery. WARN : 20/07/2017 09:28:35 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 20/07/2017 09:28:35 > 3. When phone turns on, press "Volume+" key. INFO : 20/07/2017 09:28:45 > Found phone on INFO : 20/07/2017 09:28:46 > Firmware write started. INFO : 20/07/2017 09:28:46 > Writing PIT section... INFO : 20/07/2017 09:28:51 > PIT section has been written successfully. INFO : 20/07/2017 09:28:51 > Writing bcm_boot section... INFO : 20/07/2017 09:28:53 > bcm_boot section has been written successfully. INFO : 20/07/2017 09:28:53 > Writing loke section... INFO : 20/07/2017 09:28:56 > loke section has been written successfully. INFO : 20/07/2017 09:28:56 > Writing boot section... INFO : 20/07/2017 09:28:59 > boot section has been written successfully. INFO : 20/07/2017 09:28:59 > Writing system section... INFO : 20/07/2017 09:29:47 > system section has been written successfully. INFO : 20/07/2017 09:29:47 > Writing userdata section... INFO : 20/07/2017 09:29:50 > userdata section has been written successfully. INFO : 20/07/2017 09:29:50 > Writing param_lfs section... INFO : 20/07/2017 09:29:52 > param_lfs section has been written successfully. INFO : 20/07/2017 09:29:52 > Writing modem section... INFO : 20/07/2017 09:29:56 > modem section has been written successfully. INFO : 20/07/2017 09:29:56 > Writing cache section... INFO : 20/07/2017 09:30:01 > cache section has been written successfully. INFO : 20/07/2017 09:30:01 > Firmware writing successfully completed. INFO : 20/07/2017 09:30:01 > Performed by 2.5.6 Software version. |
07-20-2017, 07:58 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to use different USB ports of PC motherboard for connection and make sure not to use any USB hubs for connection of the box. Also it is recommended to disconnect all other boxes and dongles to prevent conflicts. |
