06-05-2016, 16:41 | #1 (permalink) |
Registered User Join Date: Apr 2008 Location: searching new...
Member: 749179 Status: Offline Sonork: 100.1668876 Thanks Meter: 68 | Need help from octoplus supporter j500g cert fail i have done writing cert with octoplus but still unknown so is there any advice from supporter .. Thanks in advanced ... |
06-05-2016, 17:37 | #2 (permalink) |
Member: 749179 Status: Offline Sonork: 100.1668876 Thanks Meter: 68 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.6 ----------------------------------------------------------------------------------- To connect SM-J500G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM560 Selected model: SM-J500G Selected file: C:\Users\SR-Computer\Desktop\SM--J500G_ 352141070382870 - Copy.cert Select Certificate2... Selected file: C:\Users\SR-Computer\Desktop\SM--J500G_ 352141070382870.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM560 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.2.6 software version but still same imei unknown |
06-06-2016, 10:48 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please perform "Read Info" operation from "Android/EFS manager" tab of the Software and post here full Software log of the operation. |
06-07-2016, 09:04 | #4 (permalink) |
Member: 749179 Status: Offline Sonork: 100.1668876 Thanks Meter: 68 | Platform: Samsung Android Selected port: COM1 Selected model: SM-J500G Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-J500G Firmware compiled date: Fri Dec 4 12:54:03 KST 2015 PDA version: J500GXXU1AOL1 CSC version: J500GOLB1AOK2 SW version: J500GXXU1AOK1 Phone SN: 00000000000 Android version: 5.1.1 (LMY48B) Country: THAILAND HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: j5ltedx Performed by 2.2.6 software version |
06-07-2016, 15:09 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please upload the following files to any file-sharing service: 1. First Security backup of the phone. 2. *.log and *.logx files of performed operations. Post here download link for these files and we will check what causes the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
06-08-2016, 06:22 | #8 (permalink) |
Member: 749179 Status: Offline Sonork: 100.1668876 Thanks Meter: 68 | Thanks for good reply from Octoplus here is uploaded files, if need more pls reply me. logs LOGS - Download - 4shared SECURITY BACKUP SECURITY BACKUP - Download - 4shared |
The Following User Says Thank You to shohag.bd For This Useful Post: |
06-15-2016, 10:48 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to do the next: 1. Read EFS of another, correctly working SM-J500G. 2. Write EFS file into your phone. 3. Repeat "Write Cert" operation. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
