05-07-2016, 23:33 | #1 (permalink) |
Insane Poster Join Date: Sep 2011
Member: 1656264 Status: Offline Thanks Meter: 6 | need help resetting FRP lock on N920W8 To connect SM-N920W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-N920W8 To put SM-N920W8 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Operation was failed! Performed by 2.2.5 software version ------------------------------------------------------------------------- It's on 6.0.1 |
05-09-2016, 10:46 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to write "sboot_N920w8_OI1" SBoot file from the Support Area as a firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
05-09-2016, 21:43 | #5 (permalink) |
Member: 1656264 Status: Offline Thanks Meter: 6 | I get error writing sboot Here's the log --------------------------------------------------------------------------------- To connect SM-N920W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: sboot_N920w8_OI1.oct Please put the phone into Download Mode and connect USB cable. To put SM-N920W8 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM163 Selected model: SM-N920W8 To put SM-N920W8 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Operation was failed! Performed by 2.2.5 software version ------------------------------------------------------------------- What do I do now? |
07-19-2016, 13:37 | #7 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 41
Member: 227726 Status: Offline Thanks Meter: 297 | n920w8 6.0.1 failed Quote:
The Following User Says Thank You to masterspargo For This Useful Post: |
07-24-2016, 21:12 | #9 (permalink) |
Major Poster Join Date: May 2013
Member: 1948768 Status: Offline Thanks Meter: 3 | they should make a clear topic about this issue , becoz all helps are gone invain for such version . clearly there is NO solution YET as of july-24-2016 . if somebody has another trick to go back doors to reset it plz let us know . bcoz sboot from 6.0.1 pc5 to 5.xx OI1 is failure . |
