10-16-2016, 12:36 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: India
Member: 949240 Status: Offline Thanks Meter: 86 | need help in samsung g935v now in download mode its showing g935a file name combination_fa60_g935v_g935aucu2apd4_cl7396706_qb9 373320.oct here is the logs Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\16-10-2016_16-35-44.log" created (10/16/2016 4:35:47 PM). INFO : 10/16/2016 4:35:54 PM > Set up system language English (file: English.ini) INFO : 10/16/2016 4:35:54 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.3.4 INFO : 10/16/2016 4:35:59 PM > ----------------------------------------------------------------------------------- INFO : 10/16/2016 4:35:59 PM > To connect SM-G935V phone you have to perform the following steps: INFO : 10/16/2016 4:35:59 PM > 1. Disconnect USB cable from phone. INFO : 10/16/2016 4:35:59 PM > 2. Go to Menu->Settings->More->About Device. INFO : 10/16/2016 4:35:59 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 10/16/2016 4:35:59 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 10/16/2016 4:35:59 PM > 5. Turn on "USB Debugging" option. INFO : 10/16/2016 4:36:50 PM > Selected firmware file: combination_fa60_g935v_g935aucu2apd4_cl7396706_qb9 373320.oct WARN : 10/16/2016 4:37:23 PM > Please put the phone into Download Mode and connect USB cable. WARN : 10/16/2016 4:37:23 PM > To put SM-G935V into Download Mode, You have to perform the following steps: WARN : 10/16/2016 4:37:23 PM > 1. Reconnect the battery. WARN : 10/16/2016 4:37:23 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 10/16/2016 4:37:23 PM > 3. When phone turns on, press "Volume+" key. INFO : 10/16/2016 4:37:23 PM > Found phone on INFO : 10/16/2016 4:37:23 PM > Firmware write started. INFO : 10/16/2016 4:37:23 PM > Writing ABOOT section... INFO : 10/16/2016 4:37:26 PM > ABOOT section has been written successfully. INFO : 10/16/2016 4:37:26 PM > Writing LKSECAPP section... INFO : 10/16/2016 4:37:28 PM > LKSECAPP section has been written successfully. INFO : 10/16/2016 4:37:28 PM > Writing XBL section... INFO : 10/16/2016 4:37:31 PM > XBL section has been written successfully. INFO : 10/16/2016 4:37:31 PM > Writing TZ section... INFO : 10/16/2016 4:37:33 PM > TZ section has been written successfully. INFO : 10/16/2016 4:37:33 PM > Writing HYP section... INFO : 10/16/2016 4:37:35 PM > HYP section has been written successfully. INFO : 10/16/2016 4:37:35 PM > Writing DEVCFG section... INFO : 10/16/2016 4:37:37 PM > DEVCFG section has been written successfully. INFO : 10/16/2016 4:37:37 PM > Writing PMIC section... INFO : 10/16/2016 4:37:39 PM > PMIC section has been written successfully. INFO : 10/16/2016 4:37:39 PM > Writing RPM section... INFO : 10/16/2016 4:37:41 PM > RPM section has been written successfully. INFO : 10/16/2016 4:37:41 PM > Writing CMNLIB section... INFO : 10/16/2016 4:37:43 PM > CMNLIB section has been written successfully. INFO : 10/16/2016 4:37:43 PM > Writing KEYMASTER section... INFO : 10/16/2016 4:37:45 PM > KEYMASTER section has been written successfully. INFO : 10/16/2016 4:37:45 PM > Writing APDP section... INFO : 10/16/2016 4:37:48 PM > APDP section has been written successfully. INFO : 10/16/2016 4:37:48 PM > Writing MSADP section... INFO : 10/16/2016 4:37:50 PM > MSADP section has been written successfully. INFO : 10/16/2016 4:37:50 PM > Writing CMNLIB64 section... INFO : 10/16/2016 4:37:52 PM > CMNLIB64 section has been written successfully. INFO : 10/16/2016 4:37:52 PM > Writing SEC section... INFO : 10/16/2016 4:37:54 PM > SEC section has been written successfully. INFO : 10/16/2016 4:37:54 PM > Writing APNHLOS section... INFO : 10/16/2016 4:37:57 PM > APNHLOS section has been written successfully. INFO : 10/16/2016 4:37:57 PM > Writing BOOT section... INFO : 10/16/2016 4:38:01 PM > BOOT section has been written successfully. INFO : 10/16/2016 4:38:01 PM > Writing RECOVERY section... INFO : 10/16/2016 4:38:05 PM > RECOVERY section has been written successfully. INFO : 10/16/2016 4:38:05 PM > Writing SYSTEM section... INFO : 10/16/2016 4:40:22 PM > SYSTEM section has been written successfully. INFO : 10/16/2016 4:40:22 PM > Writing PERSIST section... INFO : 10/16/2016 4:40:24 PM > PERSIST section has been written successfully. INFO : 10/16/2016 4:40:24 PM > Writing MODEM section... INFO : 10/16/2016 4:40:32 PM > MODEM section has been written successfully. INFO : 10/16/2016 4:40:32 PM > Writing DSP section... INFO : 10/16/2016 4:40:35 PM > DSP section has been written successfully. INFO : 10/16/2016 4:40:35 PM > Firmware writing successfully completed. INFO : 10/16/2016 4:40:35 PM > Performed by 2.3.4 software version Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\16-10-2016_16-35-44.log" closed (10/16/2016 4:41:45 PM). |
10-17-2016, 08:05 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). |
10-17-2016, 11:15 | #6 (permalink) |
Member: 949240 Status: Offline Thanks Meter: 86 | now phone restarting but when i connect in download mode for frp it says resource file were not found please connect to internet try to download manually system restarted and all applications closed and tried manually means which files shall i download |
10-17-2016, 12:02 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please check your PM, we've sent You necessary file. Place it into "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\Downloaded_resourc es\Boot" folder. |
