03-31-2014, 08:15 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Punjab(India)
Member: 652870 Status: Offline Thanks Meter: 136 | Need i537 EFS file for baseband repair Welcome to Octoplus/Octopus Box Samsung software version 1.5.1 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I537 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM21 Selected model: SGH-I537 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM21 Selected model: SGH-I537 Reading info, please wait... Detected phone model: SAMSUNG-SGH-I537 Firmware compiled date: Wed Dec 4 21:49:25 KST 2013 PDA version: I537UCUBML2 CSC version: I537ATTBML2 SW version: Unknown Phone IMEI: Unknown Android version: 4.3 (JSS15J) pls give me perfect efs file because thr is efs repair option is hidden ..... |
03-31-2014, 08:19 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. As You can see from this Software log, modem part is damaged in your device: Quote:
Most liekly, this is not EFS problem. At first, try to find and re-flash the device with different firmwares and check whether modem is correct (not Unknown). | |
04-01-2014, 06:56 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to use the latest versions of VRoot and Kingo Root Software. Last edited by Octopus box; 04-03-2014 at 06:53. |
04-03-2014, 04:14 | #5 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2088984 Status: Offline Thanks Meter: 1 | I've read how to root the i9295 installing clockwork mod recovery vía Odin and then installing super user via recovery. The only thing is the i9295 is the international version of the active will this work on the U.S at&t? Sent from my SM-N900V using Tapatalk |
04-08-2014, 20:39 | #8 (permalink) | |
Insane Poster Join Date: Jan 2008
Member: 671067 Status: Offline Thanks Meter: 13 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.5.2 ----------------------------------------------------------------------------------- To connect SGH-I537 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM276 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Dec 4 2013 Firmware released time: 22:45:20 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17125 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM276 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Dec 4 2013 Firmware released time: 22:45:20 SW version: M9615A-CEFWTAZM-4.0.17125 Old IMEI: 004400-15-202000-0 New IMEI: 352863-04-599012-9 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NVM-SGH-I537-004400152020000-08-04-2014_14-35- 16-.nvm file Firmware compiled date: Wed Dec 4 21:49:25 KST 2013 PDA version: I537UCUBML2 CSC version: I537ATTBML2 SW version: I537UCUBML2 Phone IMEI: Unknown Phone SN: RF1D478W82J Android version: 4.3 (JSS15J) Cheking Root Phone is Rooted Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Dec 4 2013 Firmware released time: 22:45:20 SW version: M9615A-CEFWTAZM-4.0.17125 Found phone on COM276 Repairing NVM for SGH-I537 phone... Write IMEI failed | |
04-22-2014, 01:35 | #10 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 732601 Status: Offline Thanks Meter: 9 | hi, please help i also have imei problems, but my baseband is fine, i tried to unlock this phone via octoplus software, when the software said please don't disconnect the phone's cable or battery, the phone never reconnected so i reconnected it manually and it ended up with error now i have corrupt imei as well and whenever i try to repair it it always ends up with Write imei failed! i've tried many times please give me a solution for this. B.R. |
04-22-2014, 06:58 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ onekikuko Hello. Please repeat repair IMEI operation and post here full Software log, we will look and say to You what to do. |
04-22-2014, 15:29 | #12 (permalink) |
Member: 732601 Status: Offline Thanks Meter: 9 | Hi, here's imei repair full log, i have to point that the phone is running os 4.3 ota update UCUBML2, in order to work with it i flashed a pwned kernel i found, the wifi was gone, then i flashed an "original kernel" the wifi were restored, but when the phone boots the word custom and a lock appear on the screen. Platform: Samsung Android Selected port: COM122 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Dec 4 2013 Firmware released time: 22:45:20 SW version: M9615A-CEFWTAZM-4.0.17125 Old IMEI: 004400-15-202000-0 New IMEI: 357365-05-344970-4 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\NVM-SGH-I537-004400152020000-22-04-2014_09-24-36-.nvm file Firmware compiled date: Wed Dec 4 21:49:25 KST 2013 PDA version: I537UCUBML2 CSC version: I537ATTBML2 SW version: I537UCUBML2 Phone IMEI: Unknown Phone SN: R38F301P4QZ Android version: 4.3 (JSS15J) Cheking Root Phone is Rooted Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Dec 4 2013 Firmware released time: 22:45:20 SW version: M9615A-CEFWTAZM-4.0.17125 Found phone on COM122 Repairing NVM for SGH-I537 phone... Write IMEI failed Platform: Samsung Android Selected port: COM122 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Dec 4 2013 Firmware released time: 22:45:20 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17125 What to do? Regards |
04-22-2014, 15:37 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Wait, we will prepare test Software version for You that can Repair IMEI via Samsung Micro UART cable and contact You. |
04-24-2014, 16:04 | #15 (permalink) |
Member: 732601 Status: Offline Thanks Meter: 9 | You didn't prepare any software, you just deleted my recent posts and did nothing about this problem, bad support. Thanks anyway Saying the truth is not "spam", and don't worry about this "test" software, got solved by Z3X.... B.R. Last edited by onekikuko; 04-24-2014 at 16:12. |
