Need PIT file N8000 64 GB i have a tablet from Russia with 64 GB internal memory, ta Need PIT file N8000 64 GB i have a tablet from Russia with 64 GB internal memory, tablet is coming from Russia need pit file 64 gb while now I'm stuck only in download mode, no recovery, can' flash any firmware, ask for pit file i can't find for 64 GB thanks |
If you have working tab you can read the pit file from the device Sent from my LT26i using Tapatalk 2 |
i don't have a working device here are only 16 or 32 64 are only in europe thanks |
someone please? i really need this to fix you can read the pit file with octopus box thanks |
i found and covert a firmware with pit file but the same error Selected firmware file: CODE_N8000XWALG7_919244_REV00_user_low_ship cu pit si toate separat.oct Please switch your phone to the download mode and connect it to a PC. To put GT-N8000 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed |
Please upload somewhere your PIT file and post here link. |
1 Attachment(s) this is the pit file i use. is coming also with a firmware with csc, mode, pda, bootloader |
We have uploaded new firmware with PIT for You ("PIT_N8000XXCMA2_OJVCMA1_XSG_United_Arab_Emirates _Android_4.1.2") into the Support Area. Please try to write this firmware and post the result here. |
same Selected firmware file: PIT_N8000XXCMA2_OJVCMA1_XSG_United_Arab_Emirates_A ndroid_4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-N8000 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed |
Try to do the next: 1. Connect the device directly to motherboard USB port. 2. Try to connect your N8000 to USB hub with external power sypply. If the problem will be the same - most likely, this is HW problem (problem with flash chip). |
Use Quote:
Use MICRO UART and post results |
Welcome to Octoplus/Octopus Box Samsung software version 1.4.6 Selected firmware file: N8000XXCMB2_RBTCMB2_Germany_Android_ 4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-N8000 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing Firmware Failed OCTOPUS team What went wrong :( Customer bought this tablet from china so he wanted to change the software because few app were in chinese i download German firmware from support now its doing this please please please OCTOPUS team help me ou |
Hello. What was the firmware version exactly in the device before You have tried to write firmware? Try to do the next: 1. Install the latest Software version (Octopus Box Downloads - Software, Drivers, Manual). 2. Fully charge device's battery. 3. Connect the device directly to motherboard USB port, don't use any USB hubs or USB PCI cards. 4. Try to write firmware again. |
Firmware was ZCCMG1 now which one must i use ? |
