Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2012
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 26 | Need PIT file N8000 64 GB i have a tablet from Russia with 64 GB internal memory, ta i have a tablet from Russia with 64 GB internal memory, tablet is coming from Russia need pit file 64 gb while now I'm stuck only in download mode, no recovery, can' flash any firmware, ask for pit file i can't find for 64 GB thanks |
![]() | #5 (permalink) |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 26 | i found and covert a firmware with pit file but the same error Selected firmware file: CODE_N8000XWALG7_919244_REV00_user_low_ship cu pit si toate separat.oct Please switch your phone to the download mode and connect it to a PC. To put GT-N8000 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed |
![]() | #8 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 20,746 | We have uploaded new firmware with PIT for You ("PIT_N8000XXCMA2_OJVCMA1_XSG_United_Arab_Emirates _Android_4.1.2") into the Support Area. Please try to write this firmware and post the result here. |
![]() | #9 (permalink) | |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 26 | Quote:
same Selected firmware file: PIT_N8000XXCMA2_OJVCMA1_XSG_United_Arab_Emirates_A ndroid_4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-N8000 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed | |
![]() | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 20,746 | Try to do the next: 1. Connect the device directly to motherboard USB port. 2. Try to connect your N8000 to USB hub with external power sypply. If the problem will be the same - most likely, this is HW problem (problem with flash chip). |
![]() | #11 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2013 Location: China
Member: 1919721 Status: Offline Thanks Meter: 11 | Use Quote:
Use MICRO UART and post results | |
![]() | #13 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2013 Location: Cape Town
Member: 1979291 Status: Offline Thanks Meter: 7 | Welcome to Octoplus/Octopus Box Samsung software version 1.4.6 Selected firmware file: N8000XXCMB2_RBTCMB2_Germany_Android_ 4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-N8000 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing Firmware Failed OCTOPUS team What went wrong ![]() Customer bought this tablet from china so he wanted to change the software because few app were in chinese i download German firmware from support now its doing this please please please OCTOPUS team help me ou |
![]() | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 20,746 | Hello. What was the firmware version exactly in the device before You have tried to write firmware? Try to do the next: 1. Install the latest Software version (Octopus Box Downloads - Software, Drivers, Manual). 2. Fully charge device's battery. 3. Connect the device directly to motherboard USB port, don't use any USB hubs or USB PCI cards. 4. Try to write firmware again. |
