06-19-2018, 20:34 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: In Mobile Lab
Member: 278476 Status: Offline Sonork: 100.1592375 Thanks Meter: 119 | Need Reset FRP and To Open Screen [Answered] trying to Turn Off FRP with Octopus Factory Service but it says Device not Found tried alot but same how to Connect and do the job Logs are below Welcome to Octoplus Box Samsung software version 2.6.9 ----------------------------------------------------------------------------------- To connect SM-C7000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Connecting to server.. Username: anjumm98 Authorization.. Checking smart card... Smart card successfully checked. Checking balance.. Your balance: 200 credits. Requesting history.. History successfully obtained! Requesting service status.. Service status successfully obtained! Performed by 2.6.9 Software version. Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Could not read info Performed by 2.6.9 Software version. Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Could not read info Performed by 2.6.9 Software version. Selected interface: USB Searching for device. Please wait... Waiting for device... Port busy Device was not found! Could not read info Performed by 2.6.9 Software version. Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Could not read info Performed by 2.6.9 Software version. Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Could not read info Performed by 2.6.9 Software version. Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Could not read info Performed by 2.6.9 Software version. Last edited by Octopus box; 06-20-2018 at 05:11. |
06-20-2018, 05:10 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Quote:
06-21-2018, 07:59 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to connect the device via Samsung micro UART C3300k cable, select "UART" interface and perform the operation using this cable. Post the result. |
06-21-2018, 08:15 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To reset FRP without loosing data perform factory reset FRP operation via server. Note, this operation will reset only FRP lock and will not reset Screen Lock. |
06-21-2018, 08:33 | #8 (permalink) | |
Member: 278476 Status: Offline Sonork: 100.1592375 Thanks Meter: 119 | Quote:
But i need to unlock Screen lock with Custom Recovery. need To Turn Off FRP Before installing Custom Recovery Can't Type *#0*# While Screen Locked Selected interface: UART Note: Type *#0*# on the phone and connect UART cable. Searching for device. Please wait... | |
06-22-2018, 05:14 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If the device doesn't answer to Software commands via USB and if it is not possible to connect the device via UART cable because of set Screen Lock, currently we don't have another solution. |
06-23-2018, 19:09 | #10 (permalink) | |
But wanted to Ask is it phone Problem or Octopus Problem becuase i could Flash the phone but not connected in Factory Service In Octopus | |
06-24-2018, 00:42 | #11 (permalink) |
Freak Poster Join Date: Mar 2013 Location: In your Mind Age: 35
Member: 1902758 Status: Offline Sonork: 100.1680534 Thanks Meter: 153 | Sir, there is no way to bypass screen lock. Some day’s before i tried many way to unlock it. I have try to off OEM on to off but Octoplus, z3x pro, EFT dongle can't do this They must add this operation in next update... Sent from my iPhone using Tapatalk Last edited by Octopus box; 06-24-2018 at 11:01. |
