10-22-2017, 11:35 | #1 (permalink) |
Junior Member Join Date: Aug 2017 Location: Londres, uk
Member: 2752737 Status: Offline Thanks Meter: 0 | Need some help with GT-I8260L Welcome to Octoplus/Octopus Box Samsung software version 2.6.0 ----------------------------------------------------------------------------------- To connect GT-I8260L phone you have to perform the following steps: ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM3 Selected model: GT-I8260L Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM7 Mode: Emergency Performed by 2.6.0 Software version. Last edited by Octopus box; 10-22-2017 at 15:38. |
10-23-2017, 09:39 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. At first You need to connect the phone correctly. To connect GT-I8260L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Also try to select another COM port manually and connect the phone. |
