12-11-2014, 23:09 | #1 (permalink) |
Banned Join Date: Aug 2013
Member: 2001842 Status: Offline Thanks Meter: 0 | need support for samsung avant sm-g386t1 |
12-12-2014, 07:27 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ juan5600 Hello. Yes, Direct Unlock is currently not supported for this device model. You can unlock it via Factory Unlock procedure. |
12-13-2014, 18:55 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. We are not providing unlock codes. If You want to unlock SM-G386T1 phone - it can be done via "Factory Unlock" procedure. To perform "Factory Unlock" You need to do the next: 1. Take out (remove from the phone) SIM and SD cards. 2. Power the phone on. 3. Connect the phone to the Box using Samsung Micro UART C3300k/C3303k cable. 4. Select proper device model in the Software list. 5. Keep phone's LCD on and unlocked during the procedure (touch LCD must be ON during the Unlock process), this is important! 6. Press "Factory Unlock" button in the Software. Note: Factory Unlock is credit-based operation. You can contact our managers in online chat at www.gsmserver.com, they will help You to purchase server credits. |
12-14-2014, 09:40 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please read here and look video manuals: http://forum.gsmhosting.com/vbb/10632357-post73.html. |
12-23-2014, 16:55 | #9 (permalink) |
Insane Poster Join Date: Dec 2014
Member: 2314949 Status: Offline Thanks Meter: 18 | well, i tried FACTORY UNLOCK and i get this ----------------------------------------------------------------------------------- Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Found phone on COM1 Reading info... Phone model: SM-G386T1 Phone IMEI: 35489706119955 MSL address: R28FA0C96E Requesting MSL code... Connecting to server Username: jkar5600 Connect successfully to server. Checking smart card... Smart card successfully checked. Sending device information... Checking balance... Your balance: 30 credits. Checking request.. Sending request... Order ID: 75042 MSL code has been obtained successfully! Deactivating MSL... Deactivating MSL failed Factory Unlock operation failed! i think i need my credits back, please, thanks |
12-23-2014, 17:08 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Fully charge phone's battery, make Factory data reset and wipe cache partition and repeat the Factory Unlock operation again. Post here the result. |
02-03-2015, 02:50 | #14 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | BUY AN UNLOCK CODE OR USE A DIRECT UNLOCK CLIENT. Stop being cheap. It's not worth it to have ALL your Avant customers come back to bitch at you because the CERT you wrote to it is now blacklisted. |
The Following 2 Users Say Thank You to ecs87 For This Useful Post: |
02-03-2015, 07:30 | #15 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
