12-22-2014, 14:18 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You can perform "Factory Unlock" operation now. Service is already available. |
12-22-2014, 14:53 | #3 (permalink) |
No Life Poster Join Date: Jun 2007 Age: 37
Member: 520810 Status: Offline Thanks Meter: 231 | phone still lock after factory unlock ----------------------------------------------------------------------------------- Connecting to server... Username: urecel Authorizing... Checking balance... Your balance: 9 credits. ----------------------------------------------------------------------------------- Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Found phone on COM11 Reading info... Modelo del teléfono: SM-G850F IMEI del teléfono: 3560100669 MSL address: R58FA0VBYV Requesting MSL code... Connecting to server Username: urecel Connect successfully to server. Checking smart card... Smart card successfully checked. Sending device information... Checking balance... Your balance: 9 credits. Checking request.. Sending request... Order ID: 74059 MSL code has been obtained successfully! Deactivating MSL... MSL deactivate successfully Liberando el teléfono... Factory Unlock operation successfully completed! To unlock please type '00000000' (8 zeros). Para aplicar los cambios, reinicie el teléfono |
12-22-2014, 15:05 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Have You entered the code "00000000"? Do the next: make Factory data reset and wipe cache partition, then repeat the "Factory Unlock" operation again, re-start the phone and enter '00000000' (8 zeros). |
12-22-2014, 15:30 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What exactly not work? Does the phone accepted the code? Also do the next: 1. Close the Software. 2. Install the latest Software version (Software). 3. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Suite\LOG\". 4. Run the Software. 5. Take out SIM and SD cards from the phone. 6. Make Factory data reset and wipe cache partition. 7. Make Factory Unlock again. 8. Close the Software. 9. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the link, we will research, where can be the problem with your device. |
12-22-2014, 15:33 | #7 (permalink) | |
Member: 520810 Status: Offline Thanks Meter: 231 | Quote:
i will do it you say | |
12-22-2014, 16:12 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to do the next: 1. Check (mark) "Skip LVOFLOCK" option in the Software. 2. Repeat the Factory Unlock operation again. 3. Write here the result. |
