09-29-2014, 14:19 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: italy
Member: 548901 Status: Offline Sonork: 100.1644756 Thanks Meter: 51 | note 2 lte n7105 help no repair --------------- Platform: Samsung Android Selected port: COM199 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 SW version: M9615ACEHWMAZD179599 Old IMEI: 354792-05-3xxxxxxxxx New IMEI: 356830-05-xxxxxxxxxx IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) -------------------------------------------------------------------- --------------- Platform: Samsung Android Selected port: COM199 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 Phone IMEI: 354792-05-304345-5 SW version: M9615ACEHWMAZD179599 -------------------------------------------------------------------- Software 4.4.2 report ok but no change imei .... |
09-29-2014, 14:21 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Do the next: 1. Install the latest Software version (Software). 2. Take out SIM and SD cards from the device. 3. Make Repair IMEI again. 4. To finish the operation, restart the phone via phone's menu (via Power ON key, don't disconnect the battery, this is important). 5. Write here the result. |
09-29-2014, 14:26 | #3 (permalink) |
Member: 548901 Status: Offline Sonork: 100.1644756 Thanks Meter: 51 | Welcome to Octoplus/Octopus Box Samsung software version 1.6.8 ----------------------------------------------------------------------------------- To connect GT-N7105 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-N7105 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM199 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 Phone IMEI: 354792-05-xxxxxxx SW version: M9615ACEHWMAZD179599 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM199 Selected model: GT-N7105 Mode: Normal Phone model: GT-N7105 Firmware compiled date: Apr 14 2014 Firmware compiled time: 18:44:19 Firmware released date: Apr 14 2014 Firmware released time: 18:44:19 SW version: M9615ACEHWMAZD179599 Old IMEI: 354792-05-xxxxxxxxx New IMEI: 356830-05-xxxxxxxxx IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) not change imei...not solve |
09-29-2014, 16:34 | #5 (permalink) |
Member: 548901 Status: Offline Sonork: 100.1644756 Thanks Meter: 51 | ok ....octopus can't repair imei at note 2 lte 4.4.2 ...... i have downgrade to 4.3 firmware from support octopus but always old imei ....... But i must reset efs (repair) first???? Last edited by Octopus box; 09-29-2014 at 18:02. |
09-29-2014, 18:03 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Upload *.log and *.logx files of "Repair IMEI" opeation and post here download links. We will check where can be the problem with Your phone. |
