12-18-2014, 00:36 | #1 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2312656 Status: Offline Thanks Meter: 3 | Note 3 N900T SEARCHING ONLY QNC ..Done downgrading to moden nb4 .. done. flashing stock rooms.. done (multiple times) have redone the process a couple times and nothing... any suggestions ? |
12-18-2014, 07:41 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Most likely, IMEI from the Certificate file, which You have used, is in the black list of your network operator. Install the latest Software version (Software) and try to use other IMEI Certificates, which we have sent You to PM. Post here (or send to us into PM) full Software log with all of your actions. |
12-19-2014, 02:34 | #4 (permalink) |
Member: 2312656 Status: Offline Thanks Meter: 3 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-N900T Selected file: C: \Users\RON\Desktop\cert note 3\Cert-SM-N900- 358476050161363-RF1D93H06MH .cert Detected phone model: SM-N900T Firmware compiled date: Mon May 19 21:44:54 KST 2014 PDA version: N900TUVUDNE6 CSC version: N900TTMBDNE6 SW version: N900TUVUDNE6 Phone IMEI: Unknown Phone SN: RV1DB29AT0X Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now Certificate has been written successfully Please, restart the phone to apply changes still the same problem |
12-19-2014, 04:39 | #5 (permalink) |
Member: 2312656 Status: Offline Thanks Meter: 3 | Welcome to Octoplus/Octopus Box Samsung software version 1.7.8 ----------------------------------------------------------------------------------- To connect SGH-M919 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-N900T Reading info, please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-N900T Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N900T Firmware compiled date: Fri Aug 22 19:12:58 KST 2014 PDA version: N900TUVUDNF9 CSC version: N900TTMBDNF9 SW version: N900TUVUDNF9 Phone IMEI: 358476050161363 Phone SN: RV1DB29AT0X Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-N900T Detected phone model: SM-N900T Firmware compiled date: Fri Aug 22 19:12:58 KST 2014 PDA version: N900TUVUDNF9 CSC version: N900TTMBDNF9 SW version: N900TUVUDNF9 Phone IMEI: 358476050161363 Phone SN: RV1DB29AT0X Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: May 09 2014 Firmware compiled time: 20:00:00 Firmware released date: Aug 22 2014 Firmware released time: 16:51:49 SW Version: M8974A-AAAANAZM-2.0.10059 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-N900T-358476050161363-18-12-2014_22-29- 40-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900T-358476050161363-18-12-2014_22-32- 06-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: May 09 2014 Firmware compiled time: 20:00:00 Firmware released date: Aug 22 2014 Firmware released time: 16:51:49 SW Version: M8974A-AAAANAZM-2.0.10059 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-N900T Selected file: C:\Users\RON\Desktop\cert note 3\Cert_SM-N900_ 359092050091226-S200012760.cert Detected phone model: SM-N900T Firmware compiled date: Fri Aug 22 19:12:58 KST 2014 PDA version: N900TUVUDNF9 CSC version: N900TTMBDNF9 SW version: N900TUVUDNF9 Phone IMEI: 358476050161363 Phone SN: RV1DB29AT0X Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now Certificate has been written successfully Please, restart the phone to apply changes |
12-19-2014, 14:59 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to make Factory data reset and wipe cache partition, re-flash the phone and write Certificates again. Also, we have sent You QCN to PM. Try to write QCN after writing Certificate. |
12-19-2014, 18:02 | #9 (permalink) |
Member: 2312656 Status: Offline Thanks Meter: 3 | Welcome to Octoplus/Octopus Box Samsung software version 1.7.8 ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-N900T Reading info, please wait... Detected phone model: SM-N900T Firmware compiled date: Fri Aug 22 19:12:58 KST 2014 PDA version: N900TUVUDNF9 CSC version: N900TTMBDNF9 SW version: N900TUVUDNF9 Phone IMEI: 358476050161363 Phone SN: RV1DB29AT0X Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-N900T Detected phone model: SM-N900T Firmware compiled date: Fri Aug 22 19:12:58 KST 2014 PDA version: N900TUVUDNF9 CSC version: N900TTMBDNF9 SW version: N900TUVUDNF9 Phone IMEI: 358476050161363 Phone SN: RV1DB29AT0X Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: May 09 2014 Firmware compiled time: 20:00:00 Firmware released date: Aug 22 2014 Firmware released time: 16:51:49 SW Version: M8974A-AAAANAZM-2.0.10059 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-N900T-358476050161363-19-12-2014_11-31- 52-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900T-358476050161363-19-12-2014_11-35- 43-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: May 09 2014 Firmware compiled time: 20:00:00 Firmware released date: Aug 22 2014 Firmware released time: 16:51:49 SW Version: M8974A-AAAANAZM-2.0.10059 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-N900T Selected file: C:\Users\RON\Desktop\cert note 3\Cert-SM-N900- 358476050161363-RF1D93H06MH.cert Detected phone model: SM-N900T Firmware compiled date: Fri Aug 22 19:12:58 KST 2014 PDA version: N900TUVUDNF9 CSC version: N900TTMBDNF9 SW version: N900TUVUDNF9 Phone IMEI: Unknown Phone SN: RV1DB29AT0X Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-N900T Reading info... Mode: Normal Firmware compiled date: May 09 2014 Firmware compiled time: 20:00:00 Firmware released date: Aug 22 2014 Firmware released time: 16:51:49 SW Version: M8974A-AAAANAZM-2.0.10059 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes still no services :/ flash a fresh stock rom wipe cache and restore wipe/repair security write cert write qnc and still nothing |
12-19-2014, 18:09 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | If You have written all Certificates, which we have sent You and network is still unavailable, there can be two reasons - all IMEIs from these Certificates are in the black list of your network operator or your device has HW issue. |
01-04-2015, 23:48 | #13 (permalink) |
Crazy Poster Join Date: Jan 2009 Location: nigeria
Member: 947508 Status: Offline Thanks Meter: 2 | Hello, I will advice you to use a cert file for SM-N900q I think that should solve your problem because I unlocked one Samsung note 3 SM-N900T with octopus box like 2days ago and after wiping the efs I wrote a cert files for sm-n900q and since then the phone has been working perfectly ok with no network problem. |
01-05-2015, 01:03 | #15 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2295291 Status: Offline Thanks Meter: 0 | the certificate i used was from n900q. i got it from the octoplus support. i read it somewhere that i need to restore the qcn to fix the problem but i have no qcn file. can someone please send me n900t qcn file. thanks |
