11-19-2017, 22:48 | #1 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2693973 Status: Offline Thanks Meter: 10 | Note 3 n900v reactive lock IF NO WHEN YOU ADDED |
The Following User Says Thank You to fatistar For This Useful Post: |
11-20-2017, 09:16 | #3 (permalink) |
Member: 2693973 Status: Offline Thanks Meter: 10 | but only recative on here is the log Welcome to Octoplus/Octopus Box Samsung software version 2.6.1 ----------------------------------------------------------------------------------- To connect SM-N900V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "##366633#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-N900V To put SM-N900V into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.6.1 Software version. |
