04-13-2016, 13:23 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | Note 3 N900w8 stuck boot loop need maybe pit file i have a note 3 N900w8 version (Canadian) the client tried to flash a wrong firmware and now i can flash firmware but sometimes can't go on recovery mode (boot loop) or if i can (rare) see the image maybe a firmware with file will help? thanks Last edited by nickmatine; 04-13-2016 at 13:29. |
04-13-2016, 15:32 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please make "Wipe cache partition", then try to write different Android 5.0 firmwares from the Support Area. |
04-13-2016, 20:43 | #3 (permalink) | |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | Quote:
the images are after factory reset and flashed all firmware from support but need a firmware with pit file made for n900w8 or n9005, should be the same | |
04-14-2016, 11:12 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write "PIT_N900W8UBU2DOL1_N900W8PCTDOK1_PCT_Android_ 5.0" firmware from the Support Area. Post here result and full Software log of "Write Firmware" operation. |
04-14-2016, 22:46 | #5 (permalink) |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | same flashed ok but is stuck on recovery booting for 20 sex after restart and again Selected firmware file: PIT_N900W8UBU2DOL1_N900W8PCTDOK1 _PCT_Android_5.0.oct Please put the phone into Download Mode and connect USB cable. To put SM-N900W8 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PIT section... PIT section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version |
04-15-2016, 11:31 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Make Factory Reset and Wipe cache partition, then try to reflash the phone again, with a simple firmware (without PIT). |
