09-20-2014, 23:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | *********note 3 password keeps showing up after full wipe tried multiple times phone wont let me go into recovery mode any ideas? |
09-22-2014, 20:25 | #4 (permalink) |
Member: 1475064 Status: Offline Thanks Meter: 347 | Welcome to Octoplus/Octopus Box Samsung software version 1.6.6 ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: N900TUVUCNB4_N900TTMBCNB4_TMB_USA (T-Mobile)_Android_4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-N900T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. stuck at t-mobile logo screen |
09-22-2014, 20:47 | #7 (permalink) | |
Member: 1475064 Status: Offline Thanks Meter: 347 | Quote:
09-23-2014, 06:45 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
09-23-2014, 21:38 | #10 (permalink) |
Freak Poster Join Date: Apr 2008 Location: gsmworld
Member: 757297 Status: Offline Thanks Meter: 36 | not 3 try hand formate with volume up key +home key +power key press same taime when mobile vibret and showing samsung logo reles all buton scree showing factory reset and wipe option use volome key for slecting . |
09-24-2014, 03:44 | #12 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | r u sure thats not n900 p or a? may be u need to check if from tmobile or sprint or at&t to reflash the right firmware also, how u wiped phone ? u say thats it wont to going into recovery mode? if u sure thats tmobile, download this firmware and odin 3.9 ,just mark on auto reboot and f.reset time http://www.**************/firmwares/3/?download=26282 or from this link Download file TMB-N900TUVUCNB4-20140305155920.zip good luck |
09-26-2014, 22:50 | #13 (permalink) | |
Member: 1475064 Status: Offline Thanks Meter: 347 | Stuck at the tmobile 4g lte logo Quote:
