05-11-2015, 16:39 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. In order to repair IMEI of SM-N900 phone You need to downgrade phone's firmware version to Android 4.4.x, then You will be able to write Cert file. |
05-14-2015, 20:24 | #3 (permalink) |
Freak Poster Join Date: May 2008
Member: 778346 Status: Offline Thanks Meter: 34 | when i flash 4.4.2 flashing failed Welcome to Octoplus/Octopus Box Samsung software version 1.9.5 ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: N900XXUENG3_N900OJVENG2_KSA_Android_ 4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-N900 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Please put the phone into Download Mode and connect USB cable. To put SM-N900 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... Writing Firmware Failed |
05-15-2015, 06:52 | #4 (permalink) |
No Life Poster Join Date: Mar 2013
Member: 1900730 Status: Offline Thanks Meter: 188 | Check my post, and mb get some lucky! http://forum.gsmhosting.com/vbb/f684...ested-1948736/ Btw, to flash use 1.9.4, The 1.9.5 have bug with flashing tool. |
