10-14-2017, 06:57 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: earth
Member: 1598016 Status: Offline Thanks Meter: 61 | note 5 n9200 flashing error frp lock ; on crom service ; on ap swrev B;3 K;0 S;1 flashing with latest N9200ZHU3DQH3_N9200ZZH3DQH3_N9200ZHU3DQH3_HOME but give error on odin sw rew invalid type frp is enable not allow download non frp bootloader binery flashing with N9200ZHU3DQH3_N9200ZZH3DQH3_N9200ZHU3DQH3_HOME.tar .md5 gives this error secure check failed (bootloader) octoplus box stop flashing before start and give this error after 6 or 7 mint WARN : 10/12/2017 2:48:57 PM > Please put the phone into Download Mode and connect USB cable. WARN : 10/12/2017 2:48:57 PM > To put SM-N9200 into Download Mode, You have to perform the following steps: WARN : 10/12/2017 2:48:57 PM > 1. Reconnect the battery. WARN : 10/12/2017 2:48:57 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 10/12/2017 2:48:57 PM > 3. When phone turns on, press "Volume+" key. INFO : 10/12/2017 2:48:57 PM > Found phone on INFO : 10/12/2017 2:48:57 PM > Firmware write started. INFO : 10/12/2017 2:48:58 PM > Writing BOOTLOADER section... ERROR : 10/12/2017 2:49:32 PM > Writing Firmware Failed INFO : 10/12/2017 2:49:32 PM > Performed by 2.5.6 Software version. WARN : 10/12/2017 2:58:27 PM > Please put the phone into Download Mode and connect USB cable. WARN : 10/12/2017 2:58:27 PM > To put SM-N9200 into Download Mode, You have to perform the following steps: WARN : 10/12/2017 2:58:27 PM > 1. Reconnect the battery. WARN : 10/12/2017 2:58:27 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 10/12/2017 2:58:27 PM > 3. When phone turns on, press "Volume+" key. INFO : 10/12/2017 2:58:27 PM > Found phone on INFO : 10/12/2017 2:58:27 PM > Firmware write started. INFO : 10/12/2017 2:58:27 PM > Writing BOOTLOADER section... ERROR : 10/12/2017 2:58:41 PM > Writing Firmware Failed INFO : 10/12/2017 2:58:41 PM > Performed by 2.5.6 Software version. what i need to do with this bloody phone???/ |
10-14-2017, 07:13 | #2 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Find compatible file for your phone nothing is wrong with bloody phone Sent from my SM-G920F using Tapatalk |
The Following User Says Thank You to onz For This Useful Post: |
10-14-2017, 08:54 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, download and install the latest Software version after try to reflash your phone again. |
10-14-2017, 09:02 | #5 (permalink) | |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Quote:
https://www.**************/firmwares...U3CQG1/184114/ | |
10-14-2017, 09:09 | #6 (permalink) | |
Member: 1598016 Status: Offline Thanks Meter: 61 | Quote:
same with latest version sir INFO : 10/12/2017 5:26:08 PM > Performed by 2.6.0 Software version. WARN : 10/12/2017 5:26:35 PM > Please put the phone into Download Mode and connect USB cable. WARN : 10/12/2017 5:26:35 PM > To put SM-N9200 into Download Mode, You have to perform the following steps: WARN : 10/12/2017 5:26:35 PM > 1. Reconnect the battery. WARN : 10/12/2017 5:26:35 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 10/12/2017 5:26:35 PM > 3. When phone turns on, press "Volume+" key. INFO : 10/12/2017 5:26:35 PM > Found phone on INFO : 10/12/2017 5:26:35 PM > Firmware write started. INFO : 10/12/2017 5:26:35 PM > Writing BOOTLOADER section... ERROR : 10/12/2017 5:27:14 PM > Writing Firmware Failed INFO : 10/12/2017 5:27:14 PM > Performed by 2.6.0 Software version. | |
10-14-2017, 09:12 | #7 (permalink) | |
10-14-2017, 09:34 | #9 (permalink) | |
