03-12-2016, 16:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | Note 5 N920C FRP lock problem [Solved] ----------------------------------------------------------------------------------- To connect SM-N920C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N920C To put SM-N920C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Performed by 2.2.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N920C To put SM-N920C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Performed by 2.2.2 software version mobile wont restart and frp still on !! Last edited by Octopus box; 03-14-2016 at 11:53. |
The Following User Says Thank You to shakeelajmal For This Useful Post: |
03-12-2016, 16:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to write "SBOOT_N920C_OJ5" SBoot file from the Support Area, then repeat "Reset FRP/Reactivation/EE" operation. Post here the result. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
03-12-2016, 17:32 | #3 (permalink) |
Member: 51639 Status: Offline Thanks Meter: 76 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.2 ----------------------------------------------------------------------------------- To connect SM-N920C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N920C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: SBOOT_N920C_OJ5.oct Please put the phone into Download Mode and connect USB cable. To put SM-N920C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.2.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N920C To put SM-N920C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Reset operation completed! Performed by 2.2.2 software version done but mobile stuck at boot logo now i am downloading latest flash files to flash it lets see what happens but i confirm frp is now off |
03-12-2016, 19:35 | #4 (permalink) |
Member: 51639 Status: Offline Thanks Meter: 76 | after flashing with latest firmware N920CXXU2BPBA note 5 working like charm and there was no frp thanks for help octopus team |
04-24-2016, 15:24 | #6 (permalink) |
Insane Poster Join Date: Jul 2014 Location: UAE
Member: 2214802 Status: Offline Sonork: 100.112534 Thanks Meter: 28 | Please put the phone into Download Mode and connect USB cable. To put SM-N920C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: SM-N920C To put SM-N920C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Reset operation completed! Performed by 2.2.4 software version |
02-12-2018, 10:44 | #7 (permalink) |
Junior Member Join Date: Nov 2017 Location: Makkah
Member: 2776515 Status: Offline Thanks Meter: 2 | Hi Dear I down grad the firm ware from 7.0 to 6.0.1, but it stuck after boot and give me error to Firmware failed Now my Note 5 model N920C is stuck on screen "An error has occurred while updating the device software" Please suggest solution Thanks Sajjad Memon |
02-12-2018, 10:51 | #8 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: pakistan Age: 27
Member: 2498409 Status: Offline Thanks Meter: 127 | Quote:
upgrade to lateset frimware | |
