02-04-2016, 11:59 | #1 (permalink) |
Insane Poster Join Date: Apr 2005 Age: 48
Member: 139905 Status: Offline Thanks Meter: 3 | Note edge Scl24 restarts on android logo after installing the unlock firmware please help |
02-04-2016, 12:11 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. If phone is not powering correctly after writing of a special firmware - most likely it is not compatible with your device. Unfortunately currently no other unlock solution for this model. To restore the phone, reflash it with original firmware. |
02-04-2016, 14:25 | #3 (permalink) | |
Member: 139905 Status: Offline Thanks Meter: 3 | Quote:
the phone is called scl24 is there any thing i did it wrong | |
02-04-2016, 14:39 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | No, You did everything correct. Special firmware might not be compatible with the device, which causes boot issues after writing of it. Unfortunately You have the case, when firmware is not suitable for your particular device. |
02-05-2016, 10:46 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If phone is not turning on correctly after writing of a special firmware - unfortunaltey no solution for such phones at the moment. |
02-06-2016, 11:47 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | You can try to find a root method here: http://forum.gsmhosting.com/vbb/f606.../#post10637865 |
