06-12-2015, 17:49 | #1 (permalink) |
Junior Member Join Date: May 2013
Member: 1932476 Status: Offline Sonork: jgfy Thanks Meter: 23 | Null IMEI or baseband N900A, N900T working solution here! to solve it now just , If the N900A null or unknown baseband Just select G900A and hit repair Efs If The N900T Null Or unknown baseband just select G900T and hit repair Efs Don't Forget to write Cert After That ................................... Hop it works for you All I fixed a lot of n900a and n900t baseband unknown by tricking the phone Last edited by Octopus box; 08-02-2017 at 07:01. |
The Following 7 Users Say Thank You to lord_awrld For This Useful Post: |
06-13-2015, 12:26 | #4 (permalink) | |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Quote:
The Following User Says Thank You to ecs87 For This Useful Post: |
01-16-2016, 04:50 | #8 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2145785 Status: Offline Thanks Meter: 15 | To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900T To put SM-G900T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Repairing EFS... EFS Repair successfully ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-N900T Selected file: C:\Users\Segundo\Documents\samsung\note 3\Cert-SM-N9000Q_3590920*******_0000000000.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-N900T Detected phone model: SM-N900T Firmware compiled date: Fri Aug 22 19:12:58 KST 2014 PDA version: N900TUVUDNF9 CSC version: N900TTMBDNF9 SW version: N900TUVUDNF9 Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: May 09 2014 Firmware compiled time: 20:00:00 Firmware released date: Aug 22 2014 Firmware released time: 16:51:49 SW Version: M8974A-AAAANAZM-2.0.10059 Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N900T-15-01-2016_20-46-02-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: May 09 2014 Firmware compiled time: 20:00:00 Firmware released date: Aug 22 2014 Firmware released time: 16:51:49 SW Version: M8974A-AAAANAZM-2.0.10059 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-N900T Selected file: C:\Users\Segundo\Documents\samsung\note 3\Cert-SM-N9000Q_3590920********_0000000000.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM3 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes |
The Following User Says Thank You to benber2.bb For This Useful Post: |
03-12-2016, 01:53 | #10 (permalink) | |
Freak Poster Join Date: Mar 2007 Location: mexico
Member: 461616 Status: Offline Thanks Meter: 32 | Quote:
THANKS MATE! B.R | |
02-25-2018, 15:30 | #13 (permalink) |
Freak Poster Join Date: Feb 2010 Location: P A K I S T A N Age: 43
Member: 1242837 Status: Offline Sonork: 100.1653310 Thanks Meter: 53 | this method is 1000000% good for bandband and imei null repair but my imei back and also baseband but 3g not working thanks |
03-26-2018, 01:43 | #14 (permalink) | |
Freak Poster Join Date: Mar 2015 Location: Nairobi
Member: 2358876 Status: Offline Thanks Meter: 78 | Sm-n900a baseband unknown --solved Quote:
PROCEDURE -Put in Download MODE -Open Z3x, Select N900a -Repair> Wipe EFS/NVm -Done VIOLAA Baseband and IMEI OK now | |
The Following User Says Thank You to Siroartz For This Useful Post: |
