Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 09-10-2017, 08:33   #1 (permalink)
Member: 2325887
Thanks Meter: 134
Thumbs up imei unkonow
Welcome to Octoplus/Octopus Box Samsung software version 2.5.8
To connect SM-J710FD phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Platform: Samsung Android
Selected port: COM3
Selected model: SM-J710FD
Detected phone model: SM-J710F
Firmware compiled date: Tue Jul 25 17:37:47 KST 2017
PDA version: J710FXXS3AQG1
CSC version: J710FOJV2AQB2
SW version: unknown
Phone SN: 00000000000
Android version: 6.0.1 (MMB29K)
Sales code: XSG
Country: UAE
HW platform: exynos5
HW Chip: exynos7870
HW Modem: unknown
Security patch level: 2017-07-01
SIM 1 status: not ready
SIM 2 status: not ready
Codename: j7xeltexx
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\Security-SM-J710FD-Unknown10-09-2017_00-29-00-.asec
file
Connecting to modem port...
Modem port was not found!
Initializing exploit...
Phone will restart now. Please don't disconnect cable!
Searching for a phone. Please wait...
Phone found.
Executing exploit...
Write IMEI failed
Performed by 2.5.8 Software version.
Old 09-10-2017, 13:24   #2 (permalink)
Member: 2613252
Thanks Meter: 1,837
Hi, the problem in addition to the unknown IMEI you also have the unknown modem part.
Having the unknown modem does not allow you to write the IMEI code.
So you have to make back the modem part correct and not unknown
You can try to write another firmware until the modem part returns correct and then try to rewrite the IMEI code
Or if you are writing different firmware you don't find a solution and the modem part remains unknown, you can try to write the security of your phone if you have backed up your phone's security with the program, or you can backup your security, try Write the security and see if the modem part returns correct and not unknown and see if the IMEI code returns to default and then try to write back the IMEI code
Old 09-11-2017, 18:19   #3 (permalink)
Member: 2541673
Thanks Meter: 39
correct, look the log, you see PDA, CSC, AND SW ...
only will work when you see SW: and see build number.. if say UNKNOWN like above log, that means the modem is not compatible and shows as busy or closed...
when read phone you see SW not unknow but say DPK4 then you are able to unlock
Old 09-12-2017, 05:45   #4 (permalink)
Member: 2325887
Thanks Meter: 134
how to repair??????????
Old 09-12-2017, 07:55   #5 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,411
Hello.
As You can see from Software log, phone's modem part is damaged:
SW version: unknown
HW Modem: unknown
This can be Software (modem firmware or EFS is damaged, or You have written unsuitable firmware) or HW problem.
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged.
Page generated in 0.22777 seconds with 9 queries
