Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 01-27-2015, 10:38   #61 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,421
@ yadav.pardeep
Hello.
Btw, You can write any IMEIs for this device, no need to write IMEI Certificates. Just root the phone and make Repair IMEIs.
Old 01-27-2015, 10:57   #62 (permalink)
yadav.pardeep's Avatar
Member: 2087865
Thanks Meter: 272
Originally Posted by Octopus box View Post
@ yadav.pardeep
Hello.
and how to repair (not registered on network)
repair imei ok write cer ok but remain not register on network
in network setting not highlited like network mode etc i have 4 phones in hand
and many phones in the market in this condition sir
after repair imei with other tools like z3x
Old 01-27-2015, 11:18   #63 (permalink)
Member: 1146942
Sonork: 100.1587278
Root the phone and make Repair IMEIs, then write QCN files, which we have sent You to PM. Create new thread with the problem and post there full Software log with all of these actions.
Old 01-27-2015, 12:25   #64 (permalink)
Member: 2087865
Thanks Meter: 272
problem solve
my problem solve after write qcn wich u pm me
thnx octopus team
graet team with full support
thnx again
octopus team
Old 01-27-2015, 12:57   #65 (permalink)
Member: 797019
Thanks Meter: 25
What is the problem exactly? Create new thread with the problem and post there full Software log with all of your actions.
Try to use IMEI Certificate for SM-G7105L from the Support Area and post the result.
Plataforma: Samsung Android
Porto seleccionado: COM16
Modelo seleccionado: SM-G7102T
Selected file: D:\OCTOPLUS\CERTIFICADOS\G7105l\cert-sm-g7105l_352695060049906.cert
Modelo do telefone detectado: SM-G7102T
Data de criação do firmware: Sat Feb 22 18:56:52 KST 2014
PDA version: G7102TVJUANB6
CSC version: G7102TZTOANB5
Versão do SW: G7102TVJUANB1
IMEI do telefone: Unknown
Phone SN: RQ1F50NEAJB
Android version: 4.3 (JLS36C)
Checking Root:
Phone is Rooted.
Checking Certificate file...
Certificate file successfully checked
Writing Certificate...
Phone connected successfully
Escrevendo novo IMEI do telefone...
Checking certificate compatibility...
Certificate is not compatible
Writing Certificate failed
Old 01-27-2015, 13:15   #66 (permalink)
Member: 797019
Thanks Meter: 25
[QUOTE=Octopus box;10823940]What is the problem exactly? Create new thread with the problem and post there full Software log with all of your actions
wipe security process done in software on the phone and not security wipe
Old 01-27-2015, 13:27   #67 (permalink)
Member: 1146942
Sonork: 100.1587278
Security was wiped successfully:
But, as You can see from your Software log, IMEI Certificate for SM-G7105L is no compatible to SM-G7102T:
You should find proper IMEI Certificate for SM-G7102T and write it.
Old 01-27-2015, 18:10   #68 (permalink)
Member: 797019
Thanks Meter: 25
what's with bug is g900m is not the g7102t
where do I find the cert g7102T or how can I read from another?
Old 01-28-2015, 08:03   #69 (permalink)
Member: 1146942
Sonork: 100.1587278
What do You mean exactly? Explain the problem in more details.
You can search or ask in general sales section of this forum, maybe someone has and will sell it to You. Currently it is impossible to read out IMEI Certificates from the Qualcomm-based devices.
Old 01-28-2015, 08:15   #70 (permalink)
Thanks Meter: 4,183
Need SM-G530H Unlock Support
Old 01-28-2015, 08:20   #71 (permalink)
Member: 1146942
Sonork: 100.1587278
Already supported, if You have IMEI Certificate. Currently we have no, wait for next Update.
Old 01-29-2015, 16:16   #72 (permalink)
Member: 797019
Thanks Meter: 25
1.8.2 version does not erase the g900m security area to write the cert
Old 01-29-2015, 17:21   #73 (permalink)
Member: 1146942
Sonork: 100.1587278
In some cases, is necessary to repeat the "Wipe Security" operation several times or re-flash the phone. Try to do the next:
1. Fully charge phone's battery.
2. Make Factory data reset and wipe cache partition.
3. Root the phone and make Wipe Security several times and check, whether IMEI becomes "Unknown". Also try to re-flash the phone with different firmwares and make Wipe Security.
4. When the IMEI becomes "Unknown", Write Certificate.
Also, look here:
http://forum.gsmhosting.com/vbb/f684.../#post10681731,
http://forum.gsmhosting.com/vbb/f684.../#post10705160,
http://forum.gsmhosting.com/vbb/f684.../#post10708907.
Old 01-30-2015, 00:26   #74 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,345
Hello, have posted very many times that if not wipe security at first time, (Imei Null/Unknown must be), try with Factory reset and Wipe Cache from recovery Manually, not import if disconnect device from cable or pc, then try other time wiping security and this time have wiped with success, now can write Cert file w/o problem
allumts
Old 01-30-2015, 00:30   #75 (permalink)
Member: 2076039
Thanks Meter: 648
For the S5, the solution is to root, pull battery, throw it back in, wipe efs. It works 100% of the time for me. No need to wipe data or cache.
For the Note 4 And Note Edge models you must write the stock recovery and cache back to the device. A data/cache wipe won't work here either.
PS. I do not have any cache+recovery files. You must either download them from the support area or make your own using the instructions found in 1000 different threads on this forum.
Page generated in 0.20404 seconds with 8 queries
