01-27-2015, 10:38 | #61 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,422 | Hello. Btw, You can write any IMEIs for this device, no need to write IMEI Certificates. Just root the phone and make Repair IMEIs. |
01-27-2015, 10:57 | #62 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: in hearts
Member: 2087865 Status: Offline Thanks Meter: 272 | Quote:
repair imei ok write cer ok but remain not register on network in network setting not highlited like network mode etc i have 4 phones in hand and many phones in the market in this condition sir after repair imei with other tools like z3x | |
01-27-2015, 11:18 | #63 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,422 | Root the phone and make Repair IMEIs, then write QCN files, which we have sent You to PM. Create new thread with the problem and post there full Software log with all of these actions. |
01-27-2015, 12:57 | #65 (permalink) | |
Major Poster Join Date: Jun 2008 Location: BAHIA BRASIL
Member: 797019 Status: Offline Thanks Meter: 25 | Quote:
Plataforma: Samsung Android Porto seleccionado: COM16 Modelo seleccionado: SM-G7102T Selected file: D:\OCTOPLUS\CERTIFICADOS\G7105l\cert-sm-g7105l_352695060049906.cert Modelo do telefone detectado: SM-G7102T Data de criação do firmware: Sat Feb 22 18:56:52 KST 2014 PDA version: G7102TVJUANB6 CSC version: G7102TZTOANB5 Versão do SW: G7102TVJUANB1 IMEI do telefone: Unknown Phone SN: RQ1F50NEAJB Android version: 4.3 (JLS36C) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Escrevendo novo IMEI do telefone... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed | |
01-27-2015, 13:15 | #66 (permalink) |
Member: 797019 Status: Offline Thanks Meter: 25 | [QUOTE=Octopus box;10823940]What is the problem exactly? Create new thread with the problem and post there full Software log with all of your actions wipe security process done in software on the phone and not security wipe |
01-27-2015, 13:27 | #67 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,422 | Security was wiped successfully: Quote:
01-27-2015, 18:10 | #68 (permalink) | |
where do I find the cert g7102T or how can I read from another? | |
01-28-2015, 08:03 | #69 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,422 | Quote:
01-28-2015, 08:20 | #71 (permalink) | |
01-29-2015, 17:21 | #73 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,422 | In some cases, is necessary to repeat the "Wipe Security" operation several times or re-flash the phone. Try to do the next: 1. Fully charge phone's battery. 2. Make Factory data reset and wipe cache partition. 3. Root the phone and make Wipe Security several times and check, whether IMEI becomes "Unknown". Also try to re-flash the phone with different firmwares and make Wipe Security. 4. When the IMEI becomes "Unknown", Write Certificate. Also, look here: http://forum.gsmhosting.com/vbb/f684.../#post10681731, http://forum.gsmhosting.com/vbb/f684.../#post10705160, http://forum.gsmhosting.com/vbb/f684.../#post10708907. |
01-30-2015, 00:26 | #74 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Hello, have posted very many times that if not wipe security at first time, (Imei Null/Unknown must be), try with Factory reset and Wipe Cache from recovery Manually, not import if disconnect device from cable or pc, then try other time wiping security and this time have wiped with success, now can write Cert file w/o problem BR allumts |
01-30-2015, 00:30 | #75 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | For the S5, the solution is to root, pull battery, throw it back in, wipe efs. It works 100% of the time for me. No need to wipe data or cache. For the Note 4 And Note Edge models you must write the stock recovery and cache back to the device. A data/cache wipe won't work here either. PS. I do not have any cache+recovery files. You must either download them from the support area or make your own using the instructions found in 1000 different threads on this forum. |
