Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-15-2016, 16:13   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 101,456
Post 🐙 Octoplus / Octopus Box Samsung v.2.3.3 - J700T, T677 and more! 🐙
Octoplus / Octopus Box Samsung Software v.2.3.3 is out!
We have added world's first support for different models of Samsung Galaxy J7 and Samsung Galaxy View!
Octoplus / Octopus Box Samsung Software v.2.3.3 Release Notes:
🐙 Added support for the following models:
- J700T - added world's first Direct Unlock, Read/Write Cert, DRK fix, Read/Write/Repair Security, Read/Write/Repair EFS, Reboot in Download/Recovery mode, Write Firmware
- J700T1 - added world's first Direct Unlock, Read/Write Cert, DRK fix, Read/Write/Repair Security, Read/Write/Repair EFS, Reboot in Download/Recovery mode, Write Firmware
- SM-T677A - added world's first Fast Unlock, Fast Read Codes, Read/Write Security, Read/Write EFS, Reboot in Recovery/Download Mode, Write Firmware
- SM-T677K - added world's first Fast Unlock, Fast Read Codes, Read/Write Security, Read/Write EFS, Reboot in Recovery/Download Mode, Write Firmware
- SM-T677L - added world's first Fast Unlock, Fast Read Codes, Read/Write Security, Read/Write EFS, Reboot in Recovery/Download Mode, Write Firmware
- SM-T677NK - added world's first Fast Unlock, Fast Read Codes, Read/Write Security, Read/Write EFS, Reboot in Recovery/Download Mode, Write Firmware
- SM-T677NL - added world's first Fast Unlock, Fast Read Codes, Read/Write Security, Read/Write EFS, Reboot in Recovery/Download Mode, Write Firmware
- SM-J3110 - added Write Firmware, Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
- SM-J3119 - added Write Firmware, Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
- SM-G610Y - added Write Firmware, Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
- SM-C5000 - added Write Firmware, Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
- SM-C7000 - added Write Firmware, Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
- SM-C700S - added Write Firmware, Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
🐙 Added Fast Read Codes * (root is not required) for the following models:
- SM-G920A, SM-G920AZ, SM-G920D, SM-G920F, SM-G920FD, SM-G920FZ, SM-G920I, SM-G920K, SM-G920L, SM-G920S, SM-G920W8
- SM-G9250, SM-G925A, SM-G925F, SM-G925FQ, SM-G925I, SM-G925K, SM-G925L, SM-G925S, SM-G925T1, SM-G925W8
- SM-T710, SM-T715, SM-T715C, SM-T715N0, SM-T715Y
- SM-T810, SM-T815, SM-T815C, SM-T815N0, SM-T815Y, SM-T817W
- SM-N9200, SM-N9208, SM-N920A, SM-N920C, SM-N920CD, SM-N920F, SM-N920G, SM-N920I, SM-N920K, SM-N920L, SM-N920S, SM-N920W8
- SM-G9287, SM-G9287C, SM-G928C, SM-G928F, SM-G928G, SM-G928I, SM-G928K, SM-G928L, SM-G928S, SM-G928T, SM-G928N0, SM-G928W8
- SM-A310F, SM-A310FD, SM-A310M, SM-A310MD, SM-A310N0, SM-A310Y
- SM-A5100, SM-A5108, SM-A510F, SM-A510FD, SM-A510K, SM-A510L, SM-A510M, SM-A510MD, SM-A510S, SM-A510Y, SM-A510YD
- SM-A7100, SM-A7108, SM-A710F, SM-A710FD, SM-A710K, SM-A710L, SM-A710M, SM-A710MD, SM-A710S, SM-A710Y
Added "FRP_bypass_instrtuctions_SideSync_Method" archive into the Support Area.
This archive contains necessary instructions and files for FRP lock removal. Method is tested for A3/A5/A7 2016 models. You can also try to use it for another models.
🐙 New Cert files were uploaded into the Support Area!
🐙 All supported operations described in details in the manual ("Cable & Manual" button in the software)
* Fast Read Codes operation will work only with old versions of firmware. If your phone has new firmware - you can try to downgrade it only on your own risk.
We recommend to use "Fast Unlock" operation, which does not require root and which works for all versions of firmware.
Download Octoplus / Octopus Box Samsung Software v.2.3.3
Find out more at: www.octoplusbox.com
The Following 60 Users Say Thank You to Gsmserver For This Useful Post:
Old 08-15-2016, 16:51   #2 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 137
This is great news in coming updates i wish i could get G935f cert compatibility
The Following User Says Thank You to Techsky For This Useful Post:
Old 08-15-2016, 17:04   #3 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,349
Yea, our developers of Octopus Team have release as always oth "Big Update"..Very Compliment for you hard Work
Finally many users can know how work the "SydeSincro" method, now is Official released and No need of Search in the web many Fake Procedure...Just use the Procedure below from Support Area...Great!!!
�� Added "FRP_bypass_instrtuctions_SideSync_Method" archive into the Support Area. This archive contains necessary instructions and files for FRP lock removal. Method is tested for A3/A5/A7 2016 models. You can also try to use it for another models.
Great Update, are Satisfied also for All other Models Added for "Fast Read Code/Unlock" withouth any ROOT...Compliment !!!!
allumts
The Following 16 Users Say Thank You to allumts For This Useful Post:
Old 08-15-2016, 17:34   #4 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Thanks Meter: 786
add full unlock samsung a5 a500w
Old 08-15-2016, 17:50   #5 (permalink)
Member: 482218
Thanks Meter: 109
other box already unlocks J700T/T1, not sure other functions but great update!
Old 08-15-2016, 18:40   #6 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 127
Thanks bro for the update.
Is it work for 6.0.1 and the after the release of 5.1.1 2016 feb?....because sidesync will not open the browser window for the above version...Could you please confirm it bro
Thanks.
The Following User Says Thank You to sky_finder For This Useful Post:
Old 08-15-2016, 18:45   #7 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 546
please add j510gn unlock
Old 08-15-2016, 19:08   #8 (permalink)
allumts's Avatar
Member: 1564612
Thanks.
Hello,
For all New release data FW.....
Just Open old release Firmware Using 7Zip And Delete the Files
Just Let
Boot.img
Recovery.img
System.img
After Delete Files Flash Phone By Octopus Because Odin sometime Will Not Flash The Files After out Edit It.
Then factory reset it and Remove FRP with Octopus
br
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 08-15-2016, 19:39   #9 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 395
How we can understand this correctly, prevent misuse?
Is it like backup/restore, or like read from one and write to other?
The Following 2 Users Say Thank You to hoang For This Useful Post:
Old 08-15-2016, 19:55   #10 (permalink)
F_X
F_X's Avatar
Member: 2273678
Thanks Meter: 290
Exactly my thoughts as well, I thought the J series had CPID integrated in them
Old 08-15-2016, 21:33   #11 (permalink)
Member: 917930
Thanks Meter: 18
Good job Octoplus Team
Old 08-15-2016, 21:36   #12 (permalink)
Member: 1779577
Sonork: 100.1622810
Thanks Meter: 8
I need a direct link to this please. Can't find it at all.
Old 08-15-2016, 21:54   #13 (permalink)
allumts's Avatar
Member: 1564612
Just select: Samsung>For Unlock Repair>SydeSincro and dowload the .Rar file.
Old 08-15-2016, 22:08   #14 (permalink)
allumts's Avatar
Member: 1564612
For who have problem for find:
"FRP_bypass_instrtuctions_SideSync_Method" from Support Area, here
Mediafire Link:
Octopus_frp_bypass_instructions_sidesync_method.ra r
allumts
The Following 6 Users Say Thank You to allumts For This Useful Post:
Old 08-16-2016, 00:09   #15 (permalink)
Member: 1636627
Thanks Meter: 18
hi team g900f all imei blocked in south africa. do u have any new certificates for this model
Page generated in 0.42721 seconds with 7 queries
