09-05-2016, 15:51 | #1 (permalink) |
Insane Poster Join Date: May 1999 Location: ITALY Age: 52
Member: 75 Status: Offline Thanks Meter: 2 | G935f FRP[Solved] ----------------------------------------------------------------------------------- To connect GT-S5570B phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090# or *#0808#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G935F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G935F Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G935F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Boot section... Boot section has been written successfully. Searching for a phone. Please wait... It remains always on searching phone,any help? Regards |
09-05-2016, 17:10 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | phone will not connect to pc for step 2 until u stop octoplus process phone connect in adb mode afterwards but when we start octoplus process it will again keep searching after step 1 Code: INFO : 9/5/2016 9:26:57 PM > ----------------------------------------------------------------------------------- INFO : 9/5/2016 9:26:58 PM > Platform: Samsung Android INFO : 9/5/2016 9:26:58 PM > Selected port: COM55 INFO : 9/5/2016 9:26:58 PM > Selected model: SM-G935T WARN : 9/5/2016 9:26:58 PM > Connecting to server... INFO : 9/5/2016 9:27:01 PM > Connecting to server...Ok! INFO : 9/5/2016 9:27:01 PM > Checking resource files... INFO : 9/5/2016 9:27:03 PM > Resource files already downloaded. WARN : 9/5/2016 9:27:03 PM > Please put the phone into Download Mode and connect USB cable. WARN : 9/5/2016 9:27:03 PM > To put SM-G935T into Download Mode, You have to perform the following steps: WARN : 9/5/2016 9:27:03 PM > 1. Reconnect the battery. WARN : 9/5/2016 9:27:03 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 9/5/2016 9:27:03 PM > 3. When phone turns on, press "Volume+" key. INFO : 9/5/2016 9:27:03 PM > Waiting for phone... INFO : 9/5/2016 9:27:03 PM > Firmware write started. INFO : 9/5/2016 9:27:03 PM > Writing Boot section... INFO : 9/5/2016 9:27:06 PM > Boot section has been written successfully. INFO : 9/5/2016 9:27:06 PM > Searching for a phone. Please wait... WARN : 9/5/2016 9:37:48 PM > Operation was canceled INFO : 9/5/2016 9:37:48 PM > Performed by 2.3.5 software version Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\05-09-2016_21-16-30.log" closed (9/5/2016 9:40:49 PM). |
09-06-2016, 16:34 | #6 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | problem solved with fresh NON-UPDATED windows7 device will not connect to pc until any process is running better make it 2 step process so no need to put phone in download mode everytime |
