Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 09-22-2016, 16:07   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 87,688
Post 🐙 Octoplus / Octopus Box Samsung v.2.3.7 - reset FRP boost! 🐙
Octoplus / Octopus Box Samsung Software v.2.3.7 is out!
We have added support for Samsung Galaxy XCover, Samsung Galaxy J7, Samsung Galaxy S6 and many other models!
Octoplus / Octopus Box Samsung Software v.2.3.7 Release Notes:
🐙 Added support for the following models:
- SM-G389F - added Direct Unlock, Read Codes, Fast Unlock, Fast Read Codes, Read/Write Cert, Read/Write security, Read/Write EFS, Write Firmware, Read PIT
- SM-J710F - added Reset FRP (auto-enable ADB)
- SM-J710FN - added Reset FRP (auto-enable ADB)
🐙 Added Reset FRP via ADB for next devices (ADB must be enabled):
- SM-G890A
- SM-G920A, SM-G920AZ, SM-G920D, SM-G920F, SM-G920FD, SM-G920FZ, SM-G920I, SM-G920K, SM-G920L, SM-G920S, SM-G920T, SM-G920T1, SM-G920W8
- SM-G9250, SM-G925A, SM-G925F, SM-G925FQ, SM-G925I, SM-G925K, SM-G925L, SM-G925S, SM-G925T, SM-G925T1, SM-G925W8
- SM-G9287, SM-G9287C, SM-G928C, SM-G928F, SM-G928G, SM-G928I, SM-G928K, SM-G928L, SM-G928N0, SM-G928S, SM-G928T, SM-G928W8
- SM-G9300, SM-G9308, SM-G930F, SM-G930FD, SM-G930K, SM-G930L, SM-G930S, SM-G930T, SM-G930T1, SM-G930U, SM-G930V, SM-G930W8
- SM-G9350, SM-G935D, SM-G935F, SM-G935FD, SM-G935J, SM-G935K, SM-G935L, SM-G935S, SM-G935T, SM-G935T1, SM-G935U, SM-G935V, SM-G935W8
- SM-J105B, SM-J105F, SM-J105H, SM-J105Y
- SM-J120A, SM-J120AZ, SM-J120F, SM-J120FN, SM-J120G, SM-J120M, SM-J120P, SM-J120W, SM-J120ZN
- SM-J200BT, SM-J200F, SM-J200G, SM-J200GU, SM-J200H, SM-J200M, SM-J200Y
- SM-J210F, SM-J210FD
- SM-J320A, SM-J320AZ, SM-J320F, SM-J320FN, SM-J320G, SM-J320H, SM-J320M, SM-J320MU, SM-J320ZN
- SM-J321AZ
- SM-J5108, SM-J510F, SM-J510FN, SM-J510G, SM-J510H, SM-J510K, SM-J510L, SM-J510N, SM-J510S, SM-J510U
- SM-N9200, SM-N9208, SM-N920A, SM-N920C, SM-N920CD, SM-N920F, SM-N920G, SM-N920I, SM-N920K, SM-N920L, SM-N920S, SM-N920T, SM-N920T, SM-N920W8
- SM-N9300, SM-N930A, SM-N930F, SM-N930FD, SM-N930K, SM-N930L, SM-N930P, SM-N930R4, SM-N930S, SM-N930T, SM-N930U, SM-N930W8
🐙 Combination firmware versions for most models are uploaded into the Support Area ("COMBINATION" folder)
🐙 New Cert files were uploaded into the Support Area! (thanks to mr.Ca0ss)
🐙 All supported operations described in details in the manual ("Cable & Manual" button in the software)
To remove FRP lock you can try to do the following:
  1. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select combination firmware, un-check partitions except "boot.img")
  2. Perform "Reset FRP" operation in the software
or..
  1. Write Full Combination Firmware
  2. Go to "Developer Options" in the phone’s Settings
  3. Check "Enable OEM unlock" option
  4. Perform Factory Data Reset
  5. Re-flash the phone with full stock (original) firmware
Note: "boot.img" from combination firmware can be not compatible with current phone's firmware. In that case phone will stuck on logo, or will be rebooting after writing of such boot. To restore the phone to its initial condition you need to re-flash it with different full stock (original) firmware (or try to write only boot of such firmware).
Note: You can write "boot.img" combination firmware or to downgrade phone's firmware version only on your own risk!
PS: If you cannot find combination firmware for your model inside "COMBINATION" folder in support area, this means we don’t have this files at the moment.
Download Octoplus / Octopus Box Samsung Software v.2.3.7
Find out more at: www.octoplusbox.com
The Following 63 Users Say Thank You to Gsmserver For This Useful Post:
Old 09-22-2016, 16:21   #2 (permalink)
Afridi gsm's Avatar
Member: 1814771
Sonork: 100.1621347
Thanks Meter: 337
Octopus team supper update
The Following 3 Users Say Thank You to Afridi gsm For This Useful Post:
Old 09-22-2016, 16:24   #3 (permalink)
Member: 1280253
Thanks Meter: 120
Team there is no advance mode J320f how to go about it ???
br
Old 09-22-2016, 16:31   #4 (permalink)
FayGsmDz's Avatar
Member: 274054
Thanks Meter: 359
thx team
still wait add J510f file "COMBINATION" in support area
hope you add soon
Old 09-22-2016, 16:43   #5 (permalink)
Member: 2519923
Thanks Meter: 2
where is j210f combination file ?????????????????????
Old 09-22-2016, 16:44   #6 (permalink)
Member: 455304
Thanks Meter: 306
nice update but why just didnt just put the part need just to enable adb rather than putting the whole firmware
Old 09-22-2016, 16:48   #7 (permalink)
IQA_SHAHEEN's Avatar
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 135
how can we activate adb if its not active in phone
br
iqa_shaheen
Old 09-22-2016, 17:00   #8 (permalink)
Member: 947347
Sonork: 100.108278
Thanks Meter: 13
Old 09-22-2016, 17:01   #9 (permalink)
Member: 266986
Thanks Meter: 5
I have a510f whit android 6.0.1 when i write combination file download whit support octopus my phone is stock in logo/
Old 09-22-2016, 17:06   #10 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,984
br
iqa_shaheen
or..
When to write right Boot.img ADB enable ....
allumts
The Following 6 Users Say Thank You to allumts For This Useful Post:
Old 09-22-2016, 17:07   #11 (permalink)
Hamidshah07's Avatar
Member: 504906
Sonork: 1604032
Thanks Meter: 124
ITS called rocking update.
Old 09-22-2016, 17:07   #12 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 20,727
Writing of "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select combination firmware, un-check partitions except "boot.img") enables ADB.
The Following 8 Users Say Thank You to Octopus box For This Useful Post:
Old 09-22-2016, 17:08   #13 (permalink)
Member: 2275060
Thanks Meter: 7
i have same issue ! a510f rebooting after downloading frp file, im currently on 6.0.1
Old 09-22-2016, 17:08   #14 (permalink)
Member: 441075
Thanks Meter: 29
thank , please update combination J105b
The Following 3 Users Say Thank You to gem38 For This Useful Post:
Old 09-22-2016, 17:14   #15 (permalink)
Crazy Poster
Member: 1988221
Sonork: slam4neon
Thanks Meter: 18
how can we activate adb if its not active in phone,
phone already got frp on it .
The Following User Says Thank You to slam4neon For This Useful Post:
Page generated in 0.38789 seconds with 7 queries
