Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 11-22-2017, 16:10   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 89,621
Post 🐙 Octoplus / Octopus Box Samsung v.2.6.2 - G930/935T direct unlock and more! 🐙
Octoplus / Octopus Box Samsung Software v.2.6.2 is out!
We continue to work hard to give Octoplus users best experience and solutions for servicing of their devices. In this update we are proud to present Reset FRP/ Reactivation solution, which works via Micro UART cable for another range of devices with eMMC memory chip!
This operation will not reset/delete user data on the device!
Added Unlock via server for Galaxy S7 SM-G930T and Galaxy S7 Edge SM-G935T!
Octoplus / Octopus Box Samsung Software v.2.6.2 Release Notes:
🐙 Added Reset FRP/Reactivation lock “Via UART (eMMC memory chip)”* operation via Micro UART cable for the following devices with eMMC memory chip with Android 7.x firmwares:
- SM-A710F, SM-A710FD, SM-A710M, SM-A710MD, SM-A710Y, SM-A710S, SM-A710K, SM-A710L
- SM-G390F, SM-G390W, SM-G390Y
🐙 Added Reset FRP/Reactivation lock “Via UART (eMMC memory chip)”* operation via Micro UART cable for next devices with eMMC memory chip with Android 6.x firmwares:
- SM-J120A, SM-J120AZ, SM-J120F, SM-J120G, SM-J120M, SM-J120FN, SM-J120P,S M-J120ZN, SM-J120W
- SM-J200F, SM-J200BT, SM-J200G, SM-J200GU,SM-J200M, SM-J200Y
- SM-J320A, SM-J320AZ, SM-J321AZ, SM-J320W8
- SM-G389F
- SM-G5500, SM-G550F, SM-G550FY, SM-G550T, SM-G550T2
- SM-G150N0, SM-G150NK, SM-G150NL, SM-G150NS, SM-G155S
- SM-T375S, SM-T375L
- SM-T377W, SM-T377T
* Note: this operation may not work for some phone’s S-boot. In this case try to write another firmware version or only S-boot from firmware and repeat the operation again.
Also note: This operation will not reset/delete user data on the device!
This new Reset FRP/Reactivation lock operation requires specific connection sequence using Samsung Micro UART (with 525 kOhm resistor inside), Micro USB and again Micro UART cables.
To perform new reset FRP operation, do the following steps:
1. Select the above mentioned device model in Software's list.
2. Press “Reset FRP / Reactivation” button.
3. Select first Reset FRP / Reactivation lock method (press “Via UART (EMMC memory chip)” button).
4. Connect the phone to Box via Samsung Micro UART cable.
5. Press and hold "Vol-" and "Power" buttons for 15-20 seconds and wait until software requests to connect Micro USB cable.
6. Connect the phone to PC via Micro USB cable. Software will read certain data.
7. Connect the phone to Box again via Samsung Micro UART cable according to Software request.
8. Press and hold "Vol-" and "Power" buttons for 15-20 seconds.
9. Follow software instructions (prompts).
🐙 Added Unlock for Galaxy S7 SM-G930T and Galaxy S7 Edge SM-G935T! Unlock operation doesn't affect KNOX and requires only 210 Octopus/Octoplus Server Credits
You can buy Octopus/Octoplus Server Credits from your local reseller or directly HERE
🐙 Added “Via UART (UFS memory chip)” operation for Samsung SM-N9200 (thanks to Mr. kashif9)
🐙 Fixed "Odin protocol error" issue within Write Firmware feature for SM-G930A/SM-G935A
Download Octoplus / Octopus Box Samsung Software v.2.6.2
Find out more at: www.octoplusbox.com
The Following 74 Users Say Thank You to Gsmserver For This Useful Post:
Old 11-22-2017, 16:22   #2 (permalink)
Member: 1990913
Thanks Meter: 20
whats the duration for G935T unlock and does it support blacklisted phones
The Following User Says Thank You to babaj1de For This Useful Post:
Old 11-22-2017, 16:25   #3 (permalink)
lyes_albert's Avatar
Member: 2669781
Thanks Meter: 140
Nice and interesting update, How long does the unlocking process for G930/35T unlocking take? Thanks
The Following User Says Thank You to lyes_albert For This Useful Post:
Old 11-22-2017, 16:28   #4 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 21,154
Unlock process takes approx. 10 minutes. Unlock process doesn't change IMEI, so if phone's IMEI is in black list of your operator/provider, it will remain blacklisted.
The Following 7 Users Say Thank You to Octopus box For This Useful Post:
Old 11-22-2017, 16:30   #5 (permalink)
Member: 2381134
Thanks Meter: 112
How many credits required for unlocking??
Sorry already saw 210 creidts thanks
The Following User Says Thank You to rara1212 For This Useful Post:
Old 11-22-2017, 16:33   #6 (permalink)
Member: 2311930
Thanks Meter: 3
Nice keep it up..........
The Following User Says Thank You to Hassanzai For This Useful Post:
Old 11-22-2017, 16:53   #7 (permalink)
Member: 1524998
Thanks Meter: 50
in case of false unlock for the t-mobile device app the credits return as you can verify and what guarantees there are, you are losing money and prestige with similar cases and tools, not mentioning any to not create an unpleasant debate, that is the team octopus the one that responds..thanks
The Following User Says Thank You to arturoh For This Useful Post:
Old 11-22-2017, 17:01   #8 (permalink)
mohamed183's Avatar
Member: 212136
Sonork: 100.1580104
Thanks Meter: 145
very good work from octopus thx
Old 11-22-2017, 17:11   #9 (permalink)
Member: 1146942
Sonork: 100.1587278
We can verify all steps of unlock operation on server, so in case if opertion will not perfromed successfully, credits will be refund.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 11-22-2017, 17:18   #10 (permalink)
Member: 2501288
Thanks Meter: 186
i want buy octopus credit only for unlock this G930T if you grante the unlock 100%
here info:
IMEI STATUS CHECK with t-mobile website:
This device has an outstanding balance that must be paid or it may not be able to be used on T-Mobile network.
For more information or assistance, please call Customer Care at 1-844-445-0540.
device APP unlock message:
regards
Old 11-22-2017, 17:36   #11 (permalink)
Member: 1524998
Thanks Meter: 50
1696/5000
the octopus v2.6.2 sofw indications for factory unlock are still
Octoplus Samsung Factory Services v.2.6.2
Factory Unlock Notice:
- Devices which DO NOT ASK FOR UNLOCK CODE are not
supported and credits will not be refunded!
- Devices with triggered KNOX in most cases are not eligible
for Factory Unlock! Credits will not be refunded!
- Devices with "Device Unlock App" (T-Mobile, MetroPCS and
AT & T) will not be refunded!
- Sprint devices are not supported and credits will not be
refunded!
- Verizon devices, which IMEIs starting with 99xx are not
Selected interface: USB
Searching for device. Please wait ...
Waiting for device ...
Device was not found!
refunded!
what exactly is the method to use for g930t and g935t..thanks
Old 11-22-2017, 17:40   #12 (permalink)
Member: 1146942
Sonork: 100.1587278
Just select SM-G930T/SM-G935T in Software list, unable USB debugging mode on the phone and press "Unlock" button.
The Following 4 Users Say Thank You to Octopus box For This Useful Post:
Old 11-22-2017, 17:44   #13 (permalink)
lolo24's Avatar
Member: 2572618
Thanks Meter: 106
I love @Octopus Team
Old 11-22-2017, 17:53   #14 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 126
g930t and g935t how many credits the box
Old 11-22-2017, 17:56   #15 (permalink)
MISHUK_SIKDER's Avatar
Member: 1245067
Sonork: 100.1612383
Thanks Meter: 16
Nice update....keep it up
Sent from my iPhone using Tapatalk
The Following User Says Thank You to MISHUK_SIKDER For This Useful Post:
Page generated in 0.48981 seconds with 8 queries
