04-20-2014, 05:24 | #47 (permalink) |
No Life Poster Join Date: Aug 2004 Location: india Age: 51
Member: 78028 Status: Offline Thanks Meter: 90 | dear pls help to solve it Welcome to Octoplus/Octopus Box Samsung software version 1.5.3 ----------------------------------------------------------------------------------- ---------- Platform: Samsung Android Selected port: COM36 Selected model: SGH-I317M Port is busy Mode: Emergency Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM40 Selected model: SGH-I317M Mode: Emergency Write IMEI failed |
04-20-2014, 07:30 | #49 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
04-21-2014, 07:30 | #51 (permalink) | |
Freak Poster Join Date: Jan 2012 Location: On Earth
Member: 1716439 Status: Offline Thanks Meter: 38 | Quote:
Enviado desde mi GT-I9505 mediante Tapatalk | |
04-21-2014, 11:11 | #52 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
if you not are good in somethingh...please read carefully HELP button in SW first of use BOX+Device+Pc... | |
04-22-2014, 16:35 | #56 (permalink) |
Junior Member Join Date: Feb 2008
Member: 705536 Status: Offline Thanks Meter: 13 | Hi, Please octoplus team, i have a box which i am using but realized the UART RJ45 Port was never working and it never connected properly despite me buying endless cables, i mean all that possible worked, the cables work fine with the Z3X box and never had a UART issue. i don't mind buying another Octuplus Box money isn't the issue, but is there a way they can test the box RJ45 Port before purchase? i normally get them from GSMserver. I finally learned how to use another Com port using a different box, but i need a permanent solution using the Octoplus box and only that box. Thanks for your support |
04-23-2014, 15:47 | #58 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 46
Member: 152445 Status: Offline Thanks Meter: 16 | repair imei sm-n900w8 not work log: INFO : 23/04/2014 9:03:37 a. m. > To connect SM-N900W8 phone you have to perform the following steps: INFO : 23/04/2014 9:03:37 a. m. > 1. Disconnect USB cable from phone. INFO : 23/04/2014 9:03:37 a. m. > 2. Go to Menu->Settings->More->About Device. INFO : 23/04/2014 9:03:37 a. m. > 3.Tap on "Build number" 7 times to enable developer options. INFO : 23/04/2014 9:03:37 a. m. > 4. Go to Menu->Settings->More->Developer options. INFO : 23/04/2014 9:03:37 a. m. > 5. Turn on "USB Debugging" option. INFO : 23/04/2014 9:03:37 a. m. > 6. Go to dial window. INFO : 23/04/2014 9:03:37 a. m. > 7. Enter "*#0808#" number. INFO : 23/04/2014 9:03:37 a. m. > 8. Select "DM+Modem+ADB". INFO : 23/04/2014 9:03:37 a. m. > 9. Press Home button. INFO : 23/04/2014 9:03:37 a. m. > 10. Go to dial window. INFO : 23/04/2014 9:03:37 a. m. > 11. Enter "*#9090#" number. INFO : 23/04/2014 9:03:37 a. m. > 12. Set "Diag config" to "USB" value. INFO : 23/04/2014 9:03:37 a. m. > 13. Restart phone. INFO : 23/04/2014 9:03:37 a. m. > 14. Press "Read Info" in software. INFO : 23/04/2014 9:05:15 a. m. > Selected firmware file: N900W8UBUBMJ4_N900W8UWMBMK2_COL_Colombia_Oct_13_An droid_4.3.oct WARN : 23/04/2014 9:05:45 a. m. > Please switch your phone to the download mode and connect it to a PC. WARN : 23/04/2014 9:05:45 a. m. > To put SM-N900W8 phone into download mode you have to perform the following steps: WARN : 23/04/2014 9:05:45 a. m. > 1. Reconnect phone battery. WARN : 23/04/2014 9:05:45 a. m. > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 23/04/2014 9:05:45 a. m. > 3. When phone turns on press "Volume+" button. INFO : 23/04/2014 9:05:46 a. m. > Found phone on INFO : 23/04/2014 9:05:46 a. m. > Firmware write started. INFO : 23/04/2014 9:05:46 a. m. > Writing SBL1 section... INFO : 23/04/2014 9:05:48 a. m. > SBL1 section has been written successfully. INFO : 23/04/2014 9:05:48 a. m. > Writing ABOOT section... INFO : 23/04/2014 9:05:50 a. m. > ABOOT section has been written successfully. INFO : 23/04/2014 9:05:50 a. m. > Writing RPM section... INFO : 23/04/2014 9:05:52 a. m. > RPM section has been written successfully. INFO : 23/04/2014 9:05:53 a. m. > Writing TZ section... INFO : 23/04/2014 9:05:55 a. m. > TZ section has been written successfully. INFO : 23/04/2014 9:05:55 a. m. > Writing DBI section... INFO : 23/04/2014 9:05:57 a. m. > DBI section has been written successfully. INFO : 23/04/2014 9:05:57 a. m. > Writing APNHLOS section... INFO : 23/04/2014 9:06:00 a. m. > APNHLOS section has been written successfully. INFO : 23/04/2014 9:06:00 a. m. > Writing BOOT section... INFO : 23/04/2014 9:06:04 a. m. > BOOT section has been written successfully. INFO : 23/04/2014 9:06:04 a. m. > Writing RECOVERY section... INFO : 23/04/2014 9:06:08 a. m. > RECOVERY section has been written successfully. INFO : 23/04/2014 9:06:09 a. m. > Writing SYSTEM section... INFO : 23/04/2014 9:13:07 a. m. > SYSTEM section has been written successfully. INFO : 23/04/2014 9:13:07 a. m. > Writing MODEM section... INFO : 23/04/2014 9:13:19 a. m. > MODEM section has been written successfully. INFO : 23/04/2014 9:13:19 a. m. > Writing CACHE section... INFO : 23/04/2014 9:13:33 a. m. > CACHE section has been written successfully. INFO : 23/04/2014 9:13:33 a. m. > Firmware writing successfully completed. INFO : 23/04/2014 9:14:35 a. m. > Selected firmware file: Root_SM-N900W8.oct.oct WARN : 23/04/2014 9:14:52 a. m. > Please switch your phone to the download mode and connect it to a PC. WARN : 23/04/2014 9:14:52 a. m. > To put SM-N900W8 phone into download mode you have to perform the following steps: WARN : 23/04/2014 9:14:52 a. m. > 1. Reconnect phone battery. WARN : 23/04/2014 9:14:52 a. m. > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 23/04/2014 9:14:52 a. m. > 3. When phone turns on press "Volume+" button. INFO : 23/04/2014 9:14:54 a. m. > Found phone on INFO : 23/04/2014 9:14:54 a. m. > Firmware write started. INFO : 23/04/2014 9:14:55 a. m. > Writing RECOVERY section... INFO : 23/04/2014 9:15:01 a. m. > RECOVERY section has been written successfully. INFO : 23/04/2014 9:15:01 a. m. > Writing CACHE section... INFO : 23/04/2014 9:15:09 a. m. > CACHE section has been written successfully. INFO : 23/04/2014 9:15:09 a. m. > Firmware writing successfully completed. INFO : 23/04/2014 9:17:56 a. m. > ----------------------------------------------------------------------------------- INFO : 23/04/2014 9:17:56 a. m. > Platform: Samsung Android INFO : 23/04/2014 9:17:56 a. m. > Selected port: COM35 INFO : 23/04/2014 9:17:56 a. m. > Selected model: SM-N900W8 INFO : 23/04/2014 9:17:57 a. m. > Port is busy INFO : 23/04/2014 9:18:05 a. m. > Mode: Emergencia INFO : 23/04/2014 9:18:10 a. m. > ----------------------------------------------------------------------------------- INFO : 23/04/2014 9:18:11 a. m. > Platform: Samsung Android INFO : 23/04/2014 9:18:11 a. m. > Selected port: COM89 INFO : 23/04/2014 9:18:11 a. m. > Selected model: SM-N900W8 INFO : 23/04/2014 9:18:11 a. m. > Mode: Normal INFO : 23/04/2014 9:18:11 a. m. > Phone model: SM-N900W8 INFO : 23/04/2014 9:18:11 a. m. > Firmware compiled date: Oct 25 2013 INFO : 23/04/2014 9:18:11 a. m. > Firmware compiled time: 21:19:18 INFO : 23/04/2014 9:18:11 a. m. > Firmware released date: Oct 25 2013 INFO : 23/04/2014 9:18:12 a. m. > Firmware released time: 21:19:18 INFO : 23/04/2014 9:18:12 a. m. > Phone IMEI: 357507-05-001133-0 INFO : 23/04/2014 9:18:12 a. m. > SW version: SET_BY_CM INFO : 23/04/2014 9:18:12 a. m. > Repairing 3G/4G... INFO : 23/04/2014 9:18:43 a. m. > 3G/4G repair successfully WARN : 23/04/2014 9:18:43 a. m. > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Plataforma: Samsung Android Puerto seleccionado: COM89 Modelo seleccionado: SM-N900W8 Modo: Normal Modelo del teléfono: SM-N900W8 Fecha de creación del firmware: Oct 25 2013 Tiempo de compilación del firmware: 21:19:18 Fecha de salida del firmware: Oct 25 2013 Tiempo de salida del firmware: 21:19:18 Versión del SW: SET_BY_CM IMEI antiguo: 004400-15-202000-0 IMEI nuevo: 357507-05-001133-0 Realizando el backup de NVM ¡La lectura de NVM está terminada! Connecting to ADB, please waite... ADB server killed. Fecha de creación del firmware: Thu Oct 31 15:55:47 KST 2013 PDA version: N900W8UBUBMJ4 CSC version: N900W8UWMBMK2 Versión del SW: N900W8UBUBMJ3 IMEI del teléfono: Unknown Phone SN: RV1D956TFKR Android version: 4.3 (JSS15J) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N900W8-Unknown-23-04-2014_09-35-41-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Please connect phone to USB cable and press OK button. Serching phone... after repair 3g/4g continuously restarts and if I do the whole process is looking for the phone |
