10-24-2014, 21:25 | #31 (permalink) |
Insane Poster Join Date: Oct 2014
Member: 2279699 Status: Offline Thanks Meter: 41 | sorry for my bad english |
10-24-2014, 22:33 | #32 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 307625 Status: Offline Thanks Meter: 25 | Platform: Samsung Android Selected port: COM94 Selected model: SM-G900T Selected file: C:\Users\User\Desktop\CERT\Cert-SM-G900F_ XXXXXX067456427_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Wed Mar 26 13:28:24 KST 2014 PDA version: G900TUVU1ANCH CSC version: G900TTMB1ANCH SW version: G900TUVU1ANCH Phone IMEI: Unknown Phone SN: RV8F41KPT7K Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now Certificate has been written successfully Please, restart the phone to apply changes |
10-24-2014, 22:40 | #33 (permalink) |
Insane Poster Join Date: Mar 2014 Location: United States, Irving
Member: 2156601 Status: Offline Thanks Meter: 3 | my g900t pauses on checking for root. Did yours go through immediately? Because its stuck on checking for root. I already rooted it of course. |
10-24-2014, 23:30 | #34 (permalink) |
No Life Poster Join Date: Oct 2004 Location: italy
Member: 85139 Status: Offline Thanks Meter: 68 | Detected phone model: SM-G900F Firmware compiled date: Thu Jul 3 14:08:46 KST 2014 PDA version: G900FXXU1ANG2 CSC version: G900FHUI1ANG3 SW version: G900FXXU1ANG2 Phone IMEI: 354886061759217 Phone SN: R58F70CCKDJ Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Writing Certificate failed g900f help |
The Following User Says Thank You to topline For This Useful Post: |
10-25-2014, 00:07 | #35 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1527885 Status: Offline Thanks Meter: 0 | Plataforma: Samsung Android Puerto seleccionado: COM19 Modelo seleccionado: SM-G900P Modelo del teléfono detectado: SM-G900P Fecha de creación del firmware: Sat Apr 5 20:26:10 KST 2014 PDA version: G900PVPU1AND2 CSC version: G900PSPT1AND2 Versión del SW: G900PVPU1AND2 IMEI del teléfono: 990004476256973 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Feb 26 2014 Firmware compiled time: G900P.04 Firmware released date: Apr 5 2014 Firmware released time: 12:17:10 SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 Reading QCN... Send SPC... Failed! |
10-25-2014, 01:19 | #37 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2280259 Status: Offline Thanks Meter: 0 | 3 QUESTIONS. What will happen when 100 phones use the same IMEI, can you reverse back to your original IMEI if u cant read ur own CERT file? Is this even free or do you need the octupus hardware box with this? Thanks in advance |
10-25-2014, 01:42 | #39 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
can u plz upload g900i cr file so i can write correct file Code: Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect GT-I9100G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G900I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900I ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900I Firmware compiled date: Fri May 30 17:40:14 KST 2014 PDA version: G900IDVU1ANE2 CSC version: G900ITNZ1ANF1 SW version: G900IDVU1ANE1 Phone IMEI: 352919063742832 Phone SN: RF8F80DZY3M Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: May 13 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 17:31:11 SW Version: MPSS.DI.2.0.1.c2.2-00019-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G900I-352919063742832-25-10-2014_12-48- 36-.qcn file Checking Root: Phone is not Rooted. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900I Reading info... Mode: Normal Firmware compiled date: May 13 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 17:31:11 SW Version: MPSS.DI.2.0.1.c2.2-00019-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! QCN read successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900I Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900I Selected file: C:\Users\salim\Desktop\g900f\Cert-SM-G900F_ 352558067456427_00000000000.cert ADB server killed. Detected phone model: SM-G900I Firmware compiled date: Fri May 30 17:40:14 KST 2014 PDA version: G900IDVU1ANE2 CSC version: G900ITNZ1ANF1 SW version: G900IDVU1ANE1 Phone IMEI: 352919063742832 Phone SN: RF8F80DZY3M Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed | |
The Following User Says Thank You to MUTUAL For This Useful Post: |
10-25-2014, 02:02 | #40 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Hello everyone, I'm new to the forums so please bear with me. I try to wipe the efs of a SM-G900T, but it doesn't go through. The program seems to not respond or go irresponsive. Then when I try to write the Cert file it always gives me a fail. It's, of course, due to the EFS still remaining in the phone. Has anyone been able to successfully wipe the efs on a SM-G900T? Thank you all in advance! BR, F_X |
10-25-2014, 03:37 | #42 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2157134 Status: Offline Thanks Meter: 8 | my status is Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect SGH-T599 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "PDA" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-G900T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM9 Mode: Normal Phone model: SM-G900T Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: Mar 26 2014 Firmware released time: 11:37:24 Phone IMEI: 35342 SW version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G900T To Unlock of the device, do the next steps: 1. Root the phone. 2. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 3. Write Certificate ("Write Cert" button). ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G900T To Repair IMEI of the device, do the next steps: 1. Root the phone. 2. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 3. Write Certificate ("Write Cert" button). ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G900T Mode: Normal Phone model: SM-G900T Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: Mar 26 2014 Firmware released time: 11:37:24 Phone IMEI: 35342 SW version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 Please, select firmware file first! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G900T Mode: Normal Phone model: SM-G900T Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: Mar 26 2014 Firmware released time: 11:37:24 Phone IMEI: 353424-06-113609-4 SW version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G900T Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G900T Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900T Firmware compiled date: Wed Mar 26 13:28:24 KST 2014 PDA version: G900TUVU1ANCH CSC version: G900TTMB1ANCH SW version: G900TUVU1ANCH Phone IMEI: 353424 Phone SN: RV8F50E9Q7X Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G900T Detected phone model: SM-G900T Firmware compiled date: Wed Mar 26 13:28:24 KST 2014 PDA version: G900TUVU1ANCH CSC version: G900TTMB1ANCH SW version: G900TUVU1ANCH Phone IMEI: 353424 Phone SN: RV8F50E9Q7X Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: Mar 26 2014 Firmware released time: 11:37:24 SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G900T-353424061136094-25-10-2014_10-28- 42-.qcn file Checking Root: STOPS HERE............. |
The Following User Says Thank You to mrdnice88347 For This Useful Post: |
10-25-2014, 03:49 | #43 (permalink) |
Member: 2157134 Status: Offline Thanks Meter: 8 | Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G900T-353424061136094-25-10-2014_10-40- 02-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G900T-353424061136094-25-10-2014_10-44- 06-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: Mar 26 2014 Firmware released time: 11:37:24 SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now NO IMEI DISPLAY ERROR SECURITY ERROR THIS PHONE HAS BEEN FLASHED WITH UNAUTHOZED SOFTWARE & IS LOCKED. CALL YOUR MOBILE OPERATOR FOR ADDIIONAL SUPPORT PLEASE NOTE THAT REPAIR/RETURN FOR THIS ISSUE MAY ADDITIONAL COST |
