10-12-2014, 12:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Onilne Mobile Technology
Member: 548479 Status: Offline Thanks Meter: 138 | i9190 unlock problem ? ----------------------------------------------------------------------------------- To connect GT-I9190 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: Root_GT-I9190.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9190 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9190 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM58 Mode: Normal Phone model: GT-I9190 Firmware compiled date: Jun 28 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 3 2014 Firmware released time: 23:23:16 Phone IMEI: 359041-05-412680-1 SW version: M8930B-AAAATAZM-3.2.27040 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM58 Selected model: GT-I9190 Mode: Normal Phone model: GT-I9190 Firmware compiled date: Jun 28 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 3 2014 Firmware released time: 23:23:16 Phone IMEI: 359041-05-412680-1 SW version: M8930B-AAAATAZM-3.2.27040 Unlocking phone... Creating NVM backup Reading NVM done! Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Mon Feb 3 22:19:20 KST 2014 PDA version: I9190XXUBNB1 CSC version: I9190OJVBNB1 SW version: I9190XXUBNB1 Phone IMEI: 359041054126801 Phone SN: RF1F239WFNN Android version: 4.2.2 (JDQ39) Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM58 Selected model: GT-I9190 Mode: Normal Phone model: GT-I9190 Firmware compiled date: Jun 28 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 3 2014 Firmware released time: 23:23:16 Phone IMEI: 359041-05-412680-1 SW version: M8930B-AAAATAZM-3.2.27040 Unlocking phone... Creating NVM backup Reading NVM done! Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Mon Feb 3 22:19:20 KST 2014 PDA version: I9190XXUBNB1 CSC version: I9190OJVBNB1 SW version: I9190XXUBNB1 Phone IMEI: 359041054126801 Phone SN: RF1F239WFNN Android version: 4.2.2 (JDQ39) Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed suppor user install but not warking?how to problem solved? |
10-13-2014, 06:19 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Quote:
