12-24-2013, 10:29 | #1 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2091104 Status: Offline Sonork: 12345678 Thanks Meter: 0 | OCTOPLUS TEAM help me about s7392...[Solved] i have a samsung s7392 handset, it was working good, i just needed to repair IMEI, I have done by SAMSUNG OCTOPLUS TOOL, But after repairing network is not accessing... KINDLY help me OCTOPLUS TEAM.. WHAT SHOULD I DO NOW???? Last edited by Octopus box; 01-16-2014 at 12:53. |
12-24-2013, 11:27 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Is your device model exactly GT-S7392? Have You written special firmware before to perform Repair IMEI operation? Please post here full Software log with all of your actions. All Software log s are saved here: "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". Also try to make Factory data reset and check whether network is available (active). Last edited by Octopus box; 12-28-2013 at 15:37. |
12-28-2013, 15:04 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | same problem with me Samsung s7392 after repairing imei on emergncy calls and no service here the logs flashing with special firmware Selected firmware file: GT-S7392_for_Unlock_and_IMEI_SN_Repair.oct Please switch your phone to the download mode and connect it to a PC. To put GT-S7392 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing SBL1 section... SBL1 section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing modem section... modem section has been written successfully. Writing DTS section... DTS section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing system section... system section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Firmware writing successfully completed. imei repair ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM60 Selected model: GT-S7392 Detected phone model: GT-S7392 SW Version: S7392DDUAMI2/S7392ODDAMI2/S7392DDUAMI2/S7392DDUAMI2 HW Version: GT-S7392MKAINS Firmware compiled date: Wed Sep 11 15:21:04 KST 2013 Phone SN: RZ1D93DA5SY Android version: 4.1.2 (JZO54K) Old IMEI A: 911307-05-061342-8 New IMEI A: 352902-02-928552-6 Writing new phone IMEI A... New IMEI successfully written. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM60 Selected model: GT-S7392 Detected phone model: GT-S7392 SW Version: S7392DDUAMI2/S7392ODDAMI2/S7392DDUAMI2/S7392DDUAMI2 HW Version: GT-S7392MKAINS Phone IMEI A: 911307-05-061342-8 Firmware compiled date: Wed Sep 11 15:21:04 KST 2013 Phone SN: RZ1D93DA5SY Android version: 4.1.2 (JZO54K) Old IMEI B: 911307-05-061342-8 New IMEI B: 357592-00-867648-3 Writing new phone IMEI B... New IMEI successfully written. Please, restart the phone to apply changes pls help me thnks in advance |
12-28-2013, 15:40 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to re-flash the phone with firmware "S7392XPUAMH2_OXAAMHC_Portugal_Android_4.1.2" from the Support Area, the make Factory data reset and select network manually. |
12-29-2013, 08:17 | #5 (permalink) | |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | pls help me Quote:
sir i done as u told Selected firmware file: S7392XPUAMH2 _OXAAMHC_Portugal_Android_4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-S7392 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing DTS section... DTS section has been written successfully. Writing modem section... modem section has been written successfully. Writing system section... system section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. after flashing with this firmware i did factory rest then selected netowrk manully it says unable to connect still no service | |
01-07-2014, 10:06 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We work on solution. Now, to make a network active, please try to write into the phone the original IMEIs (which are written on the phone's label under the battery). |
01-09-2014, 10:49 | #10 (permalink) | |
Freak Poster Join Date: Oct 2012 Location: Chennai-India
Member: 1833113 Status: Offline Sonork: 100.1623537 Thanks Meter: 40 | Quote:
need solution | |
01-09-2014, 11:25 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Yes, we work on solution. We will prepare test Software version for You in several days. Last edited by Octopus box; 01-10-2014 at 17:58. |
01-10-2014, 17:59 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ amit_deswal22 Hello. As I have said above, we work on solution. Now, to make a network active, please try to write into the phone the original IMEIs (which are written on the phone's label under the battery). |
01-16-2014, 12:01 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please check your PM, we have sent You test Software version. Make "Repair Network" and write the result here. |
