Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 10-05-2014, 13:46   #1 (permalink)
Cheater -Don't Deal with him-
Member: 1965371
Thanks Meter: 440
Octopus Box Not Detect [Solved]
Please Help ME???
The Following 2 Users Say Thank You to iPhoneUnlocke For This Useful Post:
Old 10-05-2014, 14:14   #2 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 155
install driver from BOX_DRIVERS folder..... (Dowload from official site http://octoplusbox.com/files/drivers...BoxDrivers.rar)
The Following User Says Thank You to invaderaze For This Useful Post:
Old 10-05-2014, 14:23   #3 (permalink)
Member: 1965371
Thanks Meter: 440
I am using windows 8.1 pro. please tell me how to install this drivers
The Following User Says Thank You to iPhoneUnlocke For This Useful Post:
Old 10-05-2014, 14:28   #4 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 155
try to disable driver signature checking, then install driver..... (but i think it should be work without disabling D.S. checking)
Old 10-05-2014, 14:49   #5 (permalink)
Member: 1965371
Thanks Meter: 440
All drivers installed correcty. But Not work COm port
Old 10-05-2014, 19:12   #6 (permalink)
huaweinckunlock's Avatar
Member: 2022955
Sonork: 100.1646687
Thanks Meter: 271
Wink
Sorry my english)
Hello. If the folder does not automatically set, I just need to manually install the drivers.
FT232R USB UART Driver
Driver v2.12.00 - Download
• Windows 8.1
• Windows 8.1 x64
• Windows Server 2012
• Windows 8
• Windows 8 x64
• Windows Server 2008 R2
• Windows 7
• Windows 7 x64
• Windows Server 2008 x64
• Windows Vista
• Windows Vista x64
• Windows Server 2003
• Windows Server 2003 x64
• Windows XP
• Windows XP x64
The Following User Says Thank You to huaweinckunlock For This Useful Post:
Old 10-09-2014, 21:20   #7 (permalink)
Member: 1965371
Thanks Meter: 440
http://m.youtube.com/watch?google_vi...nfxqx5sv3e1pdo
this is the video
goto youtube and search
How to install Octopus Box Correctly. 100% Working Micro UART port
Dear octopus team please add this video for our members
Old 10-10-2014, 07:34   #8 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 24,745
Yes, thanks: How to install FTDI driver on Windows 8/ 8.1 And all windows versions.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 12-26-2014, 20:56   #9 (permalink)
Member: 2317628
Windows encountered a problem installing the driver software.....
I followed the Video, LEpSCF-uqvs but received the following error when updating the USB....
Windows encountered a problem installing the driver software for your device
Windows found driver software for your device but encountered an error while attempting to install it
Smart Tronik Prishine USB serial converter
The hash for the file is not present in the specified catalogue file.
The file is likely corrupt or the victim of tampering.
If you know the manufacturer of your device you can visit its website and check the support section for driver software
Chinese Arduino nano, PC is AMD running 64 bit.
Any advice most welcome
Old 12-26-2014, 21:03   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Please look here: FT232R Repair - Official guide
Old 12-26-2014, 23:13   #11 (permalink)
Member: 2317628
Using wrong drivers... I found another link that had 64bit Drivers
Problem solved!
Basically using wrong drivers... I found another link that provided a set of drivers for a 64 bit PC.
I followed the same instructions as in afore mentioned video and it worked!
I can't post URL as is, but this might work:-
http COLON // www DOT ja DOT axxs DOT net/ftdi_driver_install DOT htm
If not search for some of this:-
KMX1 and KMX2 use an FTDI USB chip for the USB connection to your PC.
Usually Windows automatically installs FTDI VCP [Virtual COM Port] drivers however with some batches of FTDI chips the default windows drivers do NOT work. The latest version of FTDI VCP drivers also do NOT work and FTDI seem oblivious of that fact.
The previous version of FTDI VCP drivers does appear to work with all batches of FTDI chips.
When the FTDI drivers do not work with a particular batch of FTDI chips the Virtual Com Port will appear in Windows Device Manager however serial communications will not work
To rectify this situation
You need to download the;
FTDI software driver for Windows x86 CDM 202.08.28 WHQL 20Certified
FTDI software driver for Windows x64 CDM 202.08.28 20WHQL 20Certified
Old 01-04-2015, 18:41   #12 (permalink)
Member: 1676183
Sonork: 100.1655321
Thanks Meter: 9
Hello sir
Download latest setup drivers r included in it
The Following User Says Thank You to HC(aaneel) For This Useful Post:
Page generated in 0.36510 seconds with 7 queries
