04-01-2015, 20:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | Octopus Can't connect anything I am trying to connect an i747. Use red cable CT-3300K (or use USB in hub or USB in computer or other cable????) USB debugging ON *#0808# select DM+modem+ADB *#7284# UART --> PDA restart Then click read info Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM5 Phone connection failed |
04-01-2015, 20:23 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: FRANCE
Member: 2091798 Status: Offline Sonork: 100.1662559 Thanks Meter: 156 | *#7284# UART-> MODEM, USB->PDA Enable dm+modem+adb, connect usb cable directli to motherboard's usb hub and to phone, press read info...then do what you want. Do not forget to click Help button if you dont know how to do...... If i helped you, do not forget to press Thanks button |
04-01-2015, 20:40 | #3 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Nope. *#7284# UART -> Modem OK USB->PDA (don't understand) connect ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM5 Phone connection failed |
04-01-2015, 20:41 | #4 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | If click unlock ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM5 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747 Mode: Emergency Unlock for SGH-I747 phone in emergency mode can’t be done |
04-01-2015, 20:54 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Install latest Software version (Software) and perform the following steps: 1. Go to Menu->Settings->More->About Device. 2. Tap on "Build number" 7 times to enable developer options. 3. Go to Menu->Settings->More->Developer options. 4. Turn on "USB Debugging" option. 5. Go to dial window. 6. Enter "*#0808#" number. 7. Select "DM+Modem+ADB". 8. Press Home button. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" to "PDA" value. 12. Restart phone. 13. Connect the phone via Micro USB cable directly to PC. 14. Press "Read Info" in software. Try to perform "Read Info" operation on different COM ports with enabled "Manual select" option. |
04-01-2015, 20:58 | #6 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | USB debugging ON *#0808# select DM+modem+ADB *#7284# UART --> PDA restart Not detected manually on any COM port ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM5 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747 Mode: Emergency Unlock for SGH-I747 phone in emergency mode can’t be done ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM5 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-I747 Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SGH-I747 Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SGH-I747 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SGH-I747 Phone was not found on the selected port! |
04-01-2015, 21:01 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Enter "*#9090#" number, set "Diag config" to "USB" (or DM/DUM over HS-USB) value and try to perform "Read Info" on different COM ports again. |
04-02-2015, 05:55 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What is the state of your device exactly? Please read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Software) and post here full Software log with this info. |
